The WPL308 desktop barcode printer is a versatile medium-duty barcode printer that supports more printing applications than any other printer in its class. It features a double wall clamshell design, 3.5 inches color TFT display (with real time clock), thermal transfer and direct thermal printing, 8 inches per second printing speed at a 203 DPI resolution and plenty of memory: 128 MB Flash memory and 128 MB SDRAM to produce everything from higher volume 4x6 shipping labels, higher resolution product marking and graphic solutions, to high resolution labels used in electronics marking applications. Standard interfaces include USB 2.0, USB-A Host, 10/100 Mbps Ethernet and Serial connectivity, with optional 802.11a/b/g/n Wi-Fi interface.
- Wasp WPL308 - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 3.75 kg
- Max Media Size
- Roll (11.2 cm)
- Min Media Size (Custom)
- 19 mm
- Max Media Size (Custom)
- 112 mm
- Print Speed
- Up to 203 mm/sec
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB 2.0, serial, USB host
- RAM Installed (Max)
- 128 MB SDRAM
- Flash Memory Installed (Max)
- 128 MB
- Card Reader
- Language Simulation
- WPL
- Barcodes
- Code 93, Code 39, UCC/EAN-128, Code 49, GS1 DataBar, QR code, MaxiCode, Aztec code, Telepen, LOGMARS, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, PLANET, TLC39, China Post, Codablock F, Plessey, EAN-14, Code 128B, Code 128C, German Post, Code 128A, ITF-14, EAN-128, EAN-8, EAN-13, MSI, RSS, UPC-2, UPC-5
- Media Type
- Labels, continuous labels, die cut labels, fanfold labels
- Black Mark sensor, gap sensor, ribbon encode sensor, open head sensor
- Total Media Capacity
- 1 roll
- Networking
- Print server
- 2-year warranty
- 22.6 cm x 33.2 cm x 19.8 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
Printer
- Print Speed
- Up to 203 mm/sec - 203 dpi
- Built-in Devices
- 3.5 inch LCD display
- Connectivity Technology
- Wired
- Interface
- 203 dpi
- WPL
- Fonts Included
- 8 x bitmapped
- Barcodes
RAM
- 128 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 128 MB
Card Reader
- Card reader
- Supported Flash Memory Cards
- microSD
Media Handling
- Media Type
- Max Media Size
- Roll (11.2 cm)
- 19 mm
- 112 mm
- Media Sizes
- Roll (1.9 - 11.2 cm)
- Max Printing Width
- 108 mm
- Max Printing Length
- 25400 mm
- Media Thickness Range
- 0.055 mm - 0.254 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm, 38.1 mm
- 1 roll
- Media Feeders
- 1 x manual - 1 roll - Roll (11.2 cm)
- Networking
- Print server
- Connections
- 1 x LAN , 1 x serial , 1 x USB 2.0 , 1 x USB host
- Cables Included
- 1 x USB cable
- Plug and Play, FCC Class B certified, UL, TUV, cUL, CCC, RoHS, WEEE, EAC, RCM, BIS
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 25 - 85% (non-condensing)
- 22.6 cm
- 33.2 cm
- 19.8 cm
- 3.75 kg
