WASP WPL308 Desktop Barcode Printer
Quicklinx: GB7VWS00 Mfr#: 633809003493
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Roll (11.2 cm)
£379.78 ex VAT
£455.73 inc VAT
The WPL308 desktop barcode printer is a versatile medium-duty barcode printer that supports more printing applications than any other printer in its class. It features a double wall clamshell design, 3.5 inches color TFT display (with real time clock), thermal transfer and direct thermal printing, 8 inches per second printing speed at a 203 DPI resolution and plenty of memory: 128 MB Flash memory and 128 MB SDRAM to produce everything from higher volume 4x6 shipping labels, higher resolution product marking and graphic solutions, to high resolution labels used in electronics marking applications. Standard interfaces include USB 2.0, USB-A Host, 10/100 Mbps Ethernet and Serial connectivity, with optional 802.11a/b/g/n Wi-Fi interface.
Wasp WPL308 - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
3.75 kg
Max Media Size
Roll (11.2 cm)
Min Media Size (Custom)
19 mm
Max Media Size (Custom)
112 mm
Print Speed
Up to 203 mm/sec
Max Resolution (B&W)
203 dpi
USB 2.0, serial, USB host
RAM Installed (Max)
128 MB SDRAM
Flash Memory Installed (Max)
128 MB
Card Reader
Language Simulation
WPL
Barcodes
Code 93, Code 39, UCC/EAN-128, Code 49, GS1 DataBar, QR code, MaxiCode, Aztec code, Telepen, LOGMARS, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, PLANET, TLC39, China Post, Codablock F, Plessey, EAN-14, Code 128B, Code 128C, German Post, Code 128A, ITF-14, EAN-128, EAN-8, EAN-13, MSI, RSS, UPC-2, UPC-5
Media Type
Labels, continuous labels, die cut labels, fanfold labels
Black Mark sensor, gap sensor, ribbon encode sensor, open head sensor
Total Media Capacity
1 roll
Print server
22.6 cm x 33.2 cm x 19.8 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Print Speed
Up to 203 mm/sec - 203 dpi
Built-in Devices
3.5 inch LCD display
Wired
203 dpi
Language Simulation
WPL
Fonts Included
8 x bitmapped
Barcodes
RAM
RAM Installed (Max)
128 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
128 MB
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Media Handling
Media Type
Max Media Size
Roll (11.2 cm)
19 mm
112 mm
Media Sizes
Roll (1.9 - 11.2 cm)
Max Printing Width
108 mm
Max Printing Length
25400 mm
Media Thickness Range
0.055 mm - 0.254 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38.1 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (11.2 cm)
Print server
1 x LAN , 1 x serial , 1 x USB 2.0 , 1 x USB host
1 x USB cable
Plug and Play, FCC Class B certified, UL, TUV, cUL, CCC, RoHS, WEEE, EAC, RCM, BIS
Power adapter - external
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
5 °C
25 - 85% (non-condensing)
22.6 cm
33.2 cm
19.8 cm
3.75 kg
Type: Printer
Brand: WASP
