The Wasp WPL305 is a compact, powerful desktop barcode printer designed to meet your light- to medium-duty barcode printing requirements. Its durable construction, speed, and dual printing technologies make the WPL305 a leader in its class.
The WPL305 offers both direct thermal and thermal transfer printing in one printer, reducing the need for investing in additional printers that only support one type of printing process. The Wasp WPL305 is a cost effective way to print labels of all types, including shipping labels, stock labels, asset tags, medical labels, and location labels.
The WPL305 prints at speeds up to 5 inches per second at 203 dpi print resolution. The WPL305 features 8 MB of operating DRAM, 2 MB of FLASH memory & Parallel, USB, RS232 connectivity. To ensure compatibility with your application, the WPL305 includes WPL, ZPL and EPL emulations.
The WPL305 is designed to be easy to install and use. Due to its reliability, it requires little maintenance. Optional upgrades such as peel & present, label cutter, additional memory cards, and Ethernet connectivity make the WPL305 one of the most versatile barcode printers of its kind. WPL305 thermal printers are CE, FCC, TUV, & UL certified and RoHS compliant.
- Wasp WPL305 - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 3 kg
- Max Media Size
- Roll (11.8 cm)
- Max Media Size (Custom)
- 118 mm
- Print Speed
- Up to 127 mm/sec
- Max Resolution (B&W)
- 203 dpi
- Interface
- Parallel, USB, serial
- RAM Installed (Max)
- 2 MB
- Flash Memory Installed (Max)
- 1 MB
- Barcodes
- Code 93, Code 39, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix
- Media Type
- Labels
- Total Media Capacity
- 1 roll
- 1-year warranty
- 21.3 cm x 31.4 cm x 18.8 cm
- Printer Type
- Label printer - thermal transfer - monochrome
Printer
- Print Speed
- Up to 127 mm/sec - 203 dpi
- Connectivity Technology
- Wired
- Interface
- 203 dpi
- Barcodes
RAM
- 2 MB
Flash Memory
- Flash Memory
- 1 MB
Media Handling
- Media Type
- Labels
- Max Media Size
- Roll (11.8 cm)
- 118 mm
- Media Sizes
- Roll (1.9 cm), Roll (11.8 cm)
- Max Printing Width
- 108 mm
- Max Printing Length
- 990 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm
- 1 roll
- Media Feeders
- 1 x manual - 1 roll - Roll (11.8 cm)
- Expansion Slots
- Memory
- Connections
- 1 x parallel , 1 x serial , 1 x USB
- Included Accessories
- Cutter
- Cables Included
- 1 x parallel cable
- Consumables Included
- 1 x ribbon
- UL, TUV, FCC
- Power Device
- Power adapter - external
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 25 - 85%
- 21.3 cm
- 31.4 cm
- 18.8 cm
- 3 kg
