WASP WPL304 Desktop Barcode Printer with Peeler
Quicklinx: 9HKKWS00 Mfr#: 633808525170
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal / thermal transfer
£354.62 ex VAT
£425.54 inc VAT
The Wasp WPL304 desktop barcode printer provides a price-performance combination unmatched by other desktop barcode printers. With small footprint of any wasp 4-inch format printer, the WPL304 is an excellent choice for cramped workspaces.
Wasp WPL304 - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
2.3 kg
United Kingdom
Max Media Size
Roll (11.2 cm)
Min Media Size (Custom)
20 mm
Max Media Size (Custom)
112 mm
Print Speed
Up to 102 mm/sec
Max Resolution (B&W)
203 dpi
Parallel, USB, LAN, serial
200 MHz
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL, EPL, WPL
Barcodes
Code 93, Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Code 128B, Code 128C, Code 128A
Media Type
Labels
Peeler
Print server
Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows 2000/XP/Vista/7/8
20.2 cm x 25.8 cm x 17.3 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
United Kingdom
Printer
Print Speed
Up to 102 mm/sec - 203 dpi
Built-in Devices
Peeler
Wired
203 dpi
Language Simulation
ZPL, EPL, WPL
Peeler
Barcodes
200 MHz
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Labels
Max Media Size
Roll (11.2 cm)
20 mm
112 mm
Media Sizes
Roll (11.2 cm)
Max Printing Width
106 mm
Max Printing Length
2286 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38.1 mm
Media Feeders
1 x manual - 1 roll - Roll (11.2 cm)
Print server
1 x parallel , 1 x serial , 1 x USB , 1 x LAN
1 x USB cable
FCC Class B certified, UL, TUV, cUL, C-Tick Class B, CCC
5 °C
20.2 cm
25.8 cm
17.3 cm
2.3 kg
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (11.2 cm)
Brand: WASP
