The Wasp WLS8600 industrial barcode scanner features fuzzy logic technology for fast, accurate reading of damaged, dirty, and poorly printed one-dimensional (1D) barcodes typically found in industrial environments. In the yard, warehouse, distribution center, manufacturing plant or retail store, the WLS8600 industrial barcode scanner offers superior performance, reliability, and user-friendly ergonomics to improve productivity. Multiple on-board interfaces ensure flexible plug-and-play host connectivity.
Reads damaged 1D barcodes for maximum industrial productivity
The Wasp WLS8600 industrial barcode scanner features fuzzy logic technology for fast, accurate reading of damaged, dirty, and poorly printed one-dimensional (1D) barcodes typically found in industrial environments. In the yard, warehouse, distribution center, manufacturing plant or retail store, the WLS8600 industrial barcode scanner offers superior performance, reliability, and user-friendly ergonomics to improve productivity. Multiple on-board interfaces ensure flexible plug-and-play host connectivity. -
Advanced data capture technology for tough environments
As innovative as it is rugged, the WLS8600 delivers the ergonomic and operational features for scan-intensive industrial applications. The scanner operates in a wide range of temperatures and has a water and particulate sealing rating of IP65. The WLS8600 maintains its reliability even when subjected to repeated drops on concrete. For applications requiring quick access and convenient storage, the WLS8600 features a built-in metal hook for attachment. Two, large LED-enhancing windows and an extra loud beeper are strategically placed on the scanner to ensure the decode feedback is clearly visible and audible to users. -
Capturing mission-critical information the smart way
The standard WLS8600 was designed specifically for industrial applications. When you choose the WLS8600, you receive the added assurance of purchasing from Wasp.
- Wasp WLS8600 Fuzzy Logic - barcode scanner
- Barcode scanner - handheld - USB - decoded
- Minimum Bar Width
- 3 mil
- Scan Element Type
- Visible laser diode
- Scan Speed
- 35 scan / sec
- Connectivity Technology
- Wired
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
- 6.9 cm x 11.4 cm x 20.7 cm
- 295 g
- 2-year warranty
Barcode
- Interface Type
- USB
- Minimum Bar Width
- 3 mil
- Scan Element Type
- Light Source Wave Length
- 630-680 nm
- Scan Speed
- 35 scan / sec
- Max Working Distance
- 97.8 cm
- Print Contrast Signal (PCS)
- 15%
- Decode Capability
- Code 49, GS1 DataBar, Code 16K, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Stacked
- TTL Decoding
- Decoded
- Wired
- OK Notification
- LED indicator
- Reduced Space Symbology (RSS), waterproof, rugged
- 1 x USB - Type A
- Cables Included
- 1 x USB cable - 1.83 m
- RoHS, IP65
- OS Required
- 6.9 cm
- 11.4 cm
- 20.7 cm
- 295 g
- Limited warranty - 2 years , Technical support - lifetime
- -30 °C
- 50 °C
- 0 - 90% (non-condensing)
- Drop Specification
- 2 m to concrete
