WASP WLR 8950 SBR Extended Range Laser Aiming Barcode Scanner with USB Cable
Quicklinx: GB73WS00 Mfr#: 633809002717
Type: Barcode scanner
Form Factor: Handheld
  • Windows 8 (32/64 bits)
22 In Stock
£81.36 ex VAT
£97.63 inc VAT
The Wasp WLR8950 SBR extended range laser aiming barcode scanner has it all: it's faster, reliable, cost effective and easy to use. It features SBR (Screen Barcode Readable) laser based technology which makes it capable of reading on screen barcodes of smart phones and tablets, and since it has no moving parts, it is more durable than the traditional laser barcode scanner. The SBR technology used in the WLR8950 is also safe for human eyes.
Wasp WLR 8950 SBR - barcode scanner
Barcode scanner - handheld - USB - decoded
Black, yellow
Minimum Bar Width
3 mil
Scan Element Type
CCD
Scan Speed
280 scan / sec
Wired
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
2.6 cm x 16 cm x 8 cm
115 g
Black, yellow
Barcode
Interface Type
USB
Minimum Bar Width
3 mil
Scan Element Type
CCD
Light Source Wave Length
650 nm
Scan Speed
280 scan / sec
Print Contrast Signal (PCS)
30%
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Telepen, Code 32, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, China Post, UK-Plessey, EAN-8, EAN-13
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
1 x USB - Type A
1 x USB cable - external - 2.1 m
FCC Class B certified, EN55022, FCC Part 15 B, WEEE, FDA, RoHS2, IEC 60825-1 Class 1, EN 55032, EN 60825-1 Class 1
Electric Current Required
200 mA (operating), 80 mA (standby)
2.6 cm
16 cm
8 cm
115 g
0 - 95% (non-condensing)
Drop Specification
1.8 m
Brand: WASP
