The Wasp WLR8950 SBR extended range laser aiming barcode scanner has it all: it's faster, reliable, cost effective and easy to use. It features SBR (Screen Barcode Readable) laser based technology which makes it capable of reading on screen barcodes of smart phones and tablets, and since it has no moving parts, it is more durable than the traditional laser barcode scanner. The SBR technology used in the WLR8950 is also safe for human eyes.
- Wasp WLR 8950 SBR - barcode scanner
- Barcode scanner - handheld - USB - decoded
- Black, yellow
- Minimum Bar Width
- 3 mil
- Scan Element Type
- CCD
- Scan Speed
- 280 scan / sec
- Connectivity Technology
- Wired
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
- 2.6 cm x 16 cm x 8 cm
- 115 g
- 2-year warranty
- Black, yellow
Barcode
- Interface Type
- USB
- Minimum Bar Width
- 3 mil
- Scan Element Type
- CCD
- Light Source Wave Length
- 650 nm
- Scan Speed
- 280 scan / sec
- Print Contrast Signal (PCS)
- 30%
- Decode Capability
- UPC-A, UPC-E, EAN-8, EAN-13, Industrial 2 of 5, Codabar, Matrix 2 of 5, Code 11, Code 93, Code 32, Code 128, Code 39, Interleaved 2 of 5, China Post, MSI-Plessey, UK-Plessey, UCC/EAN-128, Telepen, IATA, GS1 DataBar
- TTL Decoding
- Decoded
- Wired
- OK Notification
- Beeper, LED indicator
- 1 x USB - Type A
- Cables Included
- 1 x USB cable - external - 2.1 m
- FCC Class B certified, FCC Part 15 B, EN55022, EN 55032, EN 60825-1 Class 1, FDA, IEC 60825-1 Class 1, RoHS2, WEEE
- Electric Current Required
- 200 mA (operating), 80 mA (standby)
- OS Required
- 2.6 cm
- 16 cm
- 8 cm
- 115 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Drop Specification
- 1.8 m
