WASP WDI4700 2D Barcode Scanner with USB Cable
Quicklinx: GB78WS00 Mfr#: 633809007149
Type: Barcode scanner
Form Factor: Handheld
£255.51 ex VAT
£306.61 inc VAT
The Wasp WDI4700 2D scanner is a multipurpose digital imager designed to offer an ergonomic scanning experience to the user and an outstanding performance thanks to its megapixel sensor with white-illumination 2D technology.
The WDI4700 motion-sensing technology detects the user's movements to switch automatically between presentation and handheld reading without the need of a stand. It also allows the user to program the aimer and sensor according to the user's preferences.
Thanks to its highly visible 4-Dot aimer, the WDI4700 can define exact reading zones to reduce accidental reads, while the aimer's center cross provides a locator for targeted scanning in a multiple barcode environment. In addition, its visible white illumination is easier on the eyes and reads colored labels better.
The WDI4700 omnidirectional scanner can read 1D and 2D, postal and composite codes (PDF417) at a fast speed even from mobile devices. It also features enhanced optics to improve motion tolerance and high-speed imaging to read fast moving codes. This makes it ideal for a wide range of industries, such as mobile marketing or ticketing applications, retail (POS), light manufacturing, healthcare, access control, transportation, entertainment, commercial services like postal, banks, public administration, utilities, etc.
Wasp WDI4700 - barcode scanner
Barcode scanner - handheld - USB - decoded
Black, yellow
Minimum Bar Width
4 mil
Scan Element Type
2D imager
Sensor Resolution
1280 x 800
Wired
10.9 cm x 6.8 cm x 16.6 cm
161 g
Black, yellow
Barcode
Interface Type
USB
Minimum Bar Width
4 mil
Scan Element Type
2D imager
Sensor Resolution
1280 x 800
Light Source Wave Length
650 nm
Max Working Distance
58 cm
Skew (Degrees)
65
Pitch (Degrees)
65
Print Contrast Signal (PCS)
15%
Decode Capability
Code 93, UPC, PDF417, Data Matrix, QR code, GS1 DataBar, Aztec code, China Han Xin Code, MaxiCode, Micro QR code, Australian Post, China Post, Intelligent Mail Barcode, Japanese Post, Kix (Netherlands) Post, PLANET, Portuguese Post, Postnet, Royal Mail, RM4SCC, Swedish Post, EAN/JAN, GS1 DataBar Composites, GS1 DataBar Expanded Stacked, GS1 DataBar Stacked, GS1 DataBar Stacked Omnidirectional, MacroPDF417, MicroPDF417, UPC A Composite, UPC E Composite
TTL Decoding
Decoded
Wired
OK Notification
LED indicator, beeper
Green Spot technology
1 x USB - Type A
1 x USB cable - 1.83 m
IP52
Electric Current Required
400 mA (operating), 90 mA (standby)
10.9 cm
6.8 cm
16.6 cm
161 g
50 °C
0 - 95% (non-condensing)
Drop Specification
1.8 m to concrete
Brand: WASP
