WASP WDI4600 Laser 1D & 2D Barcode Scanner (USB)
Quicklinx: 9V90WS00 Mfr#: 633808929701
  • Windows 8 (32/64 bits)
Rapidly read 1D and 2D barcodes including QR codes with the Wasp WDI4600 2D barcode scanner. The WDI4600 streamlines data entry, allowing you to instantly add barcode data to spreadsheets, word documents, and databases.
Ideal for:
  • High-volume 1D/2D barcode scanning
  • Office and retail Point-of-sale
  • Healthcare
  • Shipping & receiving
  • Hospitality, travel, and entertainment
Rapidly read 1D and 2D barcodes, including QR codes, with the Wasp WDI4600 barcode scanner. The WDI4600 streamlines data entry and allows you to instantly add barcode data to spreadsheets, word documents, and databases. Use the WDI4600 to improve efficiency and eliminate data-entry errors in healthcare, retail, office, shipping and receiving, travel, hospitality, manufacturing, and more.
Installing and using the WDI4600 is fast and easy. Connect the WDI4600 directly to your PC's USB port, and you're ready to begin scanning 1D and 2D barcodes. A built-in, 4-Dot aiming guide sets a precise reading zone and reduces accidental reads. The laser's centre cross offers a targeted scanning when multiple barcodes are in view and allows for the reading of barcodes on mobile devices. The WDI4600 works with or without the use of a stand and automatically switches to the desired scanning mode.
Rely on the WDI4600 to deliver the reliability on which your business depends. The WDI4600 can with stand multiple 6' drops to concrete and carries an IP52 rating which protects it against liquid spills and dust.
The WDI4600 includes a 2-year manufacturer's warranty covering material defects.
Benefits
  • Rapidly add 1D and 2D barcode data to documents, spreadsheets and databases
  • Improve productivity and prevent data-entry errors
  • Omnidirectional reading
  • Aggressive scan engine offers flexible read range
  • Simple to implement and use
  • 4-Dot Laser aiming guide ensures accurate scanning
  • Durable design eliminates downtime due to breakage
  • Reads barcodes generated by apps on tablets and smart phones
  • Read 1D barcodes up to 25" away and 2D barcodes up to 15" away
  • Withstands multiple 6' drops to concrete
  • Compatible with optional hands-free stand for autosense scanning
  • Ergonomic design minimises user fatigue
  • Reads all common 1D barcodes, and 2D barcodes including QR Code
Wasp WDI4600 2D - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
5 mil
Scan Element Type
Visible laser diode
Wired
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
10 cm x 7.1 cm x 18.1 cm
195 g
Barcode
Interface Type
USB
Minimum Bar Width
5 mil
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Max Working Distance
63.5 cm
Skew (Degrees)
40
Pitch (Degrees)
40
Decode Capability
EAN/JAN, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Postnet, PDF417, Data Matrix, PLANET, Australian Post, British Post, China Post, Japanese Post, Kix (Netherlands) Post, Korea Post, MacroPDF417, RM4SCC, Royal Mail, Micro QR code, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Composites, GS1 DataBar Stacked, China Han Xin Code
TTL Decoding
Decoded
Wired
OK Notification
LED indicator
Reduced Space Symbology (RSS), dustproof
1 x USB - Type A
1 x USB cable - 1.83 m
IP52
Electric Current Required
65 mA (standby), 170 mA (operating)
10 cm
7.1 cm
18.1 cm
195 g
Limited warranty - 2 years , Technical support - lifetime
50 °C
5 - 95%
Drop Specification
1.8 m to concrete
