WASP WDI4200 2D USB Barcode Scanner
Quicklinx: GB77WS00 Mfr#: 633809002847
Type: Barcode scanner
Form Factor: Handheld
25 In Stock
£110.23 ex VAT
£132.27 inc VAT
The Wasp WDI4200 2D barcode scanner is compact, lightweight, ergonomic and efficient. It is able to read long and truncated 1D barcodes and larger 2D barcodes from close distances and from different angles, whether printed or displayed on a smartphone or tablet. It also features green spot technology for visual good-read feedback and a beeper for audio good-read feedback, which can be silenced when needed.
The Wasp WDI4200 is built to last: It includes rubber over the seams to protect it when dropped. It is IP42 rated against water and dust and is drop resistant up to 5 ft. These characteristics make the Wasp WDI4200 2D barcode scanner the perfect data collector device for a broad range of industries and applications such as: retail, light manufacturing, document and billing processing, banking and financial environments and more.
Wasp WDI4200 - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
4 mil
Scan Element Type
2D imager
Sensor Resolution
640 x 480
Wired
7.1 cm x 6.6 cm x 17.1 cm
120 g
Barcode
Interface Type
USB
Minimum Bar Width
4 mil
Scan Element Type
2D imager
Sensor Resolution
640 x 480
Skew (Degrees)
65
Pitch (Degrees)
65
Print Contrast Signal (PCS)
20%
Decode Capability
EAN/JAN, Code 93, GS1 DataBar, QR code, MaxiCode, Aztec code, MicroPDF417, UPC, Postnet, PDF417, Data Matrix, PLANET, Australian Post, China Post, Japanese Post, Kix (Netherlands) Post, MacroPDF417, RM4SCC, Royal Mail, Micro QR code, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, Swedish Post, GS1 DataBar Composites, GS1 DataBar Stacked, China Han Xin Code, Portuguese Post, Intelligent Mail Barcode, UPC A Composite, UPC E Composite
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Green Spot technology
1 x USB - Type A
1 x USB cable - 1.83 m
RoHS, WEEE, IP42, EN 485, IEC 62471, FCC CFR47 Part 15 B Class B
Electric Current Required
90 mA (standby), 170 mA (operating)
7.1 cm
6.6 cm
17.1 cm
120 g
50 °C
5 - 95% (non-condensing)
Drop Specification
1.5 m to concrete
Brand: WASP
