WASP WaspNest WWR2900 Pen Barcode Scanner, USB
Quicklinx: G9WYWS00 Mfr#: 633808931339
Type: Barcode scanner
Form Factor: Handheld
  • Windows 8 (32/64 bits)
£125.09 ex VAT
£150.10 inc VAT
The Wasp WWR2900 series barcode scanner is the most cost-effective way to read barcodes. The "pen" or "wand" style scans 1D barcodes on contact and scans even the widest of barcodes.
Whether you need quick access to data from an invoice, membership card, or any barcoded material, the Wasp WWR2900 series pen barcode scanner is the perfect tool for repetitive data entry. The WWR2900 pen barcode scanner is a reliable, cost-effective way to read barcodes. Scanned data appears on your screen as if you typed it from your keyboard. Increase your productivity and reduce costly data entry errors with the easy-to-use WWR2900 series barcode scanner.
Wasp WWR 2900 Pen Scanner - with WaspNest Suite - barcode scanner
Barcode scanner - handheld - decoded
Minimum Bar Width
5 mil
Scan Field Width
1 mm
Scan Element Type
Wand
Scan Speed
600 mm / sec
Wired
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
15 cm x 2.2 cm x 2.96 cm
76 g
Barcode
Minimum Bar Width
5 mil
Scan Field Width
1 mm
Scan Element Type
Wand
Light Source Wave Length
650 nm
Scan Speed
600 mm / sec
Print Contrast Signal (PCS)
60%
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, ISBN, Telepen, Code 32, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Code 3 of 9, Interleaved 2 of 5, MSI-Plessey, China Post
TTL Decoding
Decoded
Wired
1 x USB - Type A
1 x USB cable - external - 1.83 m
FCC Class A certified
15 cm
2.2 cm
2.96 cm
76 g
50 °C
0 - 95% (non-condensing)
Drop Specification
1.85 m to concrete
Brand: WASP
