Wasp WCS3905 CCD Scanner - barcode scanner
Quicklinx: 501FWS00 Mfr#: 633808502935
Type: Barcode scanner
Form Factor: Handheld
Max Paper Size: [N/A]
Compatibility: PC
24 In Stock
£54.83 ex VAT
£65.79 inc VAT
The Wasp WCS3900 barcode scanner series are the most popular CCD barcode scanning devices in the Wasp product line. Manufactured for durability yet employing an exclusive ergonomic design for comfort, the WCS3900 and WCS3905 barcode scanners are the best in their class.
For fast connection, the WCS3900 can simply be plugged into a keyboard wedge via USB or PS/2. Both barcode scanners send data to an active application just like it was typed on a keyboard. They are designed for retail, point of sale, or any repetitive process where time and accuracy are important factors in making business succeed. The WCS3900 CCD barcode scanner is a contact scanner that reads barcodes up to 1" away with a maximum barcode width of 3.25".
An optional stand is available for hands-free scanning applications.
Barcode scanner - handheld - USB - decoded
United Kingdom
Scan Field Width
8 cm
Scan Element Type
CCD
Scan Speed
45 scan / sec
Wired
9.2 cm x 18.8 cm x 2.7 cm
125 g
United Kingdom
Barcode
Interface Type
USB
Scan Field Width
8 cm
Scan Element Type
CCD
Light Source Wave Length
660 nm
Scan Speed
45 scan / sec
Max Working Distance
2.5 cm
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, ISBN, Code 32, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, China Post, IATA 2 of 5, ISSN, UK-Plessey
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
1 x USB - Type A
1 x USB cable - external
FCC Class A certified
9.2 cm
18.8 cm
2.7 cm
125 g
50 °C
20 - 80%
Compatibility: PC
Brand: WASP
