WASP HC1 Mobile Computer
Quicklinx: BF8SWS00 Mfr#: 633808391317
£1,126.89 ex VAT
£1,352.26 inc VAT
The Wasp HC1 mobile computer combines fast, reliable, rugged construction with the flexibility and versatility you need for today's aggressive business environments. Effectively scan 1D barcodes with the HC1's integrated laser scan engine, and instantly download your data back to a PC using the built-in wireless, 802.11 a/b/g connectivity and optional 3.5G, GPS, and GPRS edition.
The 3.8" oversized, color LCD touch screen allows you to execute two applications at the same time. Simply combine viewing of tasks, such as rout directions and customer information, on one screen - making it easier to view your pertinent information. Engineered to minimize downtime and increase worker productivity, the HC1 mobile computer includes a robust, optimally positioned QWERTY keypad and a powerful 2200 mAh battery.
Durably designed, the HC1 mobile computer can withstand multiple 5' drops to concrete and offers an IP65 rating against water and dust - eliminating costly downtime. The HC1 is RoHS compliant and CW, FCC, BSMI, VCCI, and CC certified.
Wasp HC1 - data collection terminal - Win Embedded Handheld 6.5 - 512 MB - 3.8"
Data collection terminal - rugged
Operating System
Microsoft Windows Embedded Handheld 6.5
Display
3.8" TFT - 800 x 480
Marvell XScale PXA320
Processor Clock Speed
806 MHz
Storage
512 MB
RAM
256 MB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11a/b/g
Barcode Reader
Yes (laser)
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128
Battery Run Time
Up to 8 hours
7.4 cm x 4 cm x 17.7 cm
390 g
1-year warranty
Operating System
Display
3.8" TFT
Resolution
800 x 480
806 MHz
Storage
512 MB
RAM
256 MB - DDR SDRAM
microSD, microSDHC
Communications
802.11a/b/g
Input Device
QWERTY keyboard
Keys Qty
44
Barcodes
Barcode Reader
Scan Element Type
Laser
Barcodes
System Requirements for PC Connection
Microsoft Windows Server 2003, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008
Expansion and Connectivity
Expansion Slots
1 x microSDHC
Lithium Ion
2200 mAh
Run Time
Up to 8 hours
Recharge Time
4 hour(s)
Power adapter, stylus
USB cable
VCCI, BSMI, CCC, FCC, RoHS, IP65
7.4 cm
4 cm
17.7 cm
390 g
Limited warranty - 1 year , Technical support - lifetime
-10 °C
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Brand: WASP
Price Range Ex VAT: £1000 - £1500
