The DT92 features better ergonomics paired with a comfortable and durable pistol grip handle. With its 38-key functional keypad, and a high-visibility color graphic display with touchscreen, the DT92 is the premier solution for applications in retail, warehouse, and logistics environments.
 - Wasp DT92 - data collection terminal - Win Embedded Compact 7 - 8 GB - 3.2"
- Product Type
 - Data collection terminal - rugged
- Operating System
 - Microsoft Windows Embedded Compact 7
- Display
 - 3.2" colour TFT - LED backlight - 240 x 320
- Processor
 - Texas Instruments OMAP 4
- Processor Clock Speed
 - 1 GHz
- Storage
 - 8 GB
- RAM
 - 1 GB
- Supported Flash Memory Cards
 - microSD, microSDHC
- Wireless Connectivity
 - 802.11a/b/g/n, Bluetooth 4.0
- Barcode Reader
 - Yes (2D imager)
- Barcodes
 - GS1 DataBar, QR code, MaxiCode, Aztec code, MicroPDF417, PDF417, Data Matrix, PLANET, Australian Post, Japanese Post, Kix (Netherlands) Post, Royal Mail, Micro QR code, GS1 DataBar Composites, Intelligent Mail Barcode, US Postnet, UPC/EAN/JAN Composites, GS1-128 Composites
- Battery Run Time
 - Up to 10 hours
 - 7.6 cm x 4.2 cm x 19.3 cm
 - 388 g
 - 1-year warranty
- Product Type
- Operating System
Display
 - 3.2" colour TFT (transflective) - LED backlight
- Resolution
 - 240 x 320
 - Touch screen
- Processor
 - 1 GHz
- Storage
 - 8 GB
- RAM
 - 1 GB
- Max Supported Capacity
 - 32 GB
Communications
Input Device
 - Touch-screen, stylus, functional backlit keyboard
- Keys Qty
 - 38
Barcodes
- Barcode Reader
- Scan Element Type
 - 2D imager
- Barcodes
- Max Working Distance
 - 74 cm
- Minimum Bar Width
 - 3 mil
System Requirements for PC Connection
- OS Required
 - Microsoft Windows 2000, Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Server 2012, Microsoft Windows Vista / 7 / 8 / 10 (32/64 bits)
Expansion and Connectivity
- Expansion Slots
 - 1 x microSD
- Technology
 - Lithium Ion
- Capacity
 - 3000 mAh
- Run Time
 - Up to 10 hours
 - Green Spot technology, MIMO technology
- Included Accessories
 - Power adapter, hand strap
- Cables Included
 - USB cable
 - IP64
 - 7.6 cm
 - 4.2 cm
 - 19.3 cm
 - 388 g
 - Limited warranty - 1 year
 - -10 °C
 - 50 °C
 - 5 - 95% (non-condensing)
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 70 °C
