Wasp Bar Code CCD Scanner is the most popular solution for scanning bar codes. Its ease-of-use and durability make the CCD a favorite with customers. Wasp Bar Code CCD Scanner simply plugs between your keyboard and computer. This Scanner allows you to scan into any Windows, DOS, NT, or Mac application. Automate your data collection tasks with this easy-to-use, one-touch scanner.
- Wasp CCD Scanner - barcode scanner
- Barcode scanner - handheld - keyboard wedge
- Scan Element Type
- CCD
- Scan Speed
- 50 scan / sec
- Connectivity Technology
- Wired
- System Requirements
- Microsoft DOS, Microsoft Windows 3.x/95/98, Microsoft Windows NT, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / XP
- 8.3 cm 19.1 cm
- 0.2 kg
Barcode
- Interface Type
- Keyboard wedge
- Scan Element Type
- CCD
- Light Source Wave Length
- 660 nm
- Scan Mode
- Hand-held
- Scan Speed
- 50 scan / sec
- Decode Capability
- Code 39, UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, MSI-Plessey
- Wired
- 1 x keyboard
- Cables Included
- 1 x keyboard cable - 2.4 m
- FCC Class A certified
- OS Required
- 8.3 cm
- 19.1 cm
- 0.2 kg
- 0 °C
- 50 °C
- 20 - 85%
WASP WCS3900 CCD Scanner Stand | In Stock | £13.39 |
Customer reviews
Write a review for the WASP CCD Keyboard Wedge Scanner for PC here!
don't bother
Reviewed by chris brown. Review Posted 02/02/2006
takes multiple attempts to scan even large high quality barcodes - not a chance if the barcode is slightly damaged. Sometimes the keyboard stops working after restarting the computer.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
