WASP Barcode Labeller V6 Software
Quicklinx: 8B50WS00 Mfr#: 633808501167
Wasp Labeler is designed to meet the most demanding bar code labeling and printing requirements. This top-selling labeling package allows you to create bar code labels and print to any local or network Windows printer in just minutes. Import data directly from your corporate database. With Wasp Labeler, you can easily generate bar code labels, asset or inventory labels, address labels, and envelopes with PostNet Zip Codes, compliance labels - just about any label for practically any industry.
Wasp Labeler allows you to connect to any ODBC database. You can also import data natively (i.e. without an ODBC driver) from Microsoft Access, Microsoft Excel, Paradox, dBase, QuickBooks, plus others. Read and write to your databases, and sort and filter records. Insert any number of serialized text and/or bar codes onto the barcode label. For each text or bar code item, independently pick a starting value. Choose the magnitude and frequency for each increment or decrement value, plus set a max (or min) rollover value. Optionally, you can even save the most recently used serial value from a given print job as the next print job's starting value. Print your labels to a barcode printer or use any Windows printer such as a laser or inkjet printer. Over 100 templates are included for Avery Label stock to be used with laser printers, and inkjet printers. Simply click on any object, and all the properties for that object are presented to you to modify. Precisely size and position objects with professional alignment tools.
WaspLabeler - box pack - 1 user
Box pack
Category
Creativity application - labelling / barcode software
Licence Qty
1 user
Platform
Windows
Category
Box pack
Platform
Windows
Licencing
Licence Qty
1 user
Supported OS
Microsoft Windows 95, Microsoft Windows 98, Microsoft Windows NT
