Wacom PL720 Interactive Pen Display, 17"
Quicklinx: 8097WS00 Mfr#: PL-720OFFICE
With its 17" screen size at SXGA resolution (1,280 x 1,024 pixels) and its ergonomic PL Pen, the PL-720 allows you to input data directly on-screen - with greater speed and accuracy thanks to the perfect hand-eye-coordination. PL-720 is a perfect companion for presentations too. Control and sketch on your presentation without turning your back to the audience.
Interactive pen display technology
Wacom's patented pen technology provides a natural tool for freehand writing, annotating and navigating directly with the pen on the screen. The ergonomically designed cordless and battery-free pen provides 512 pressure levels and has a programmable double side-switch.
Wired / Wireless
Wired
Compatibility
Mac, PC
Apple MacOS X 10.2.8 or later
6 kg
5.5 cm
40 cm
36.2 cm
