The Intuos3 Grip Pen uses Wacom's patented cordless, battery-free technology and features a cushioned, contoured barrel that reduces grip effort by up to 40%. With a 1, 024 levels of pressure-sensitivity, a DuoSwitch, a built-in eraser, and three nib styles for different "feels", the Intuos3 Grip Pen gives you control, comfort, and productivity.
Waisted rubberized grip area
A longer grip area as well as optimum weight and balance reduces gripping power significantly up to 40%. -
Sensitive pen tip
With 1,024 pressure levels, the Intuos3 Grip Pen tip responds in the most sensitive way to your own method of drawing, writing, painting, dragging and clicking. Reduced activation pressure at the tip ensures ergonomic and relaxing work and increased sensitivity means you can create vignettes on screen without level transition. -
Programmable double-side switch
It is application-specific and custom programmable - from the simulation of all the soft buttons, to shortcuts, pop-up menus etc. -
Flip it over - eraser at your service
Need to erase, cover over, tone down or brighten up your artwork? Just flip the pen over for the eraser tip. Custom programmable and configurable and just as pressure and tilt sensitive as the pen tip. -
Tilt sensitive
The Intuos3 Grip Pen recognizes tilt angles of up to 60° - important for realistic paintbrush simulation, for example. -
Tool ID
Customize your pens: with tool ID each Intuos3 input device can be individually programmed and configured for each application. And these functions can be automatically activated, when the application is started.
- Wacom Intuos3 Grip Pen - active stylus
- Active stylus
- 1.5 cm x 17.5 cm
- 18 g
- Programmable side button, eraser
- Microsoft Certification
- Certified for Windows Vista
- Designed For
- Cintiq 12WX, 21UX; Intuos3
- Active stylus
- 1.5 cm
- 17.5 cm
- 18 g
Input Device
- Pressure Levels
- 1024
- Included Accessories
- Pen stand, nibs (5 pcs.)
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Designed For
- Wacom Cintiq 12WX, 21UX , Wacom Intuos3
Wacom Intuos3/Cintiq 21UX Grip Pen
