The innovative Wacom Intuos Pro pen tablet combines Wacom's finest pen capabilities and intuitive multi-touch gestures. It gives you the power to produce professional results with the precision and control you demand from your professional software. Designed for creative work, it delivers a natural and intuitive experience that extends your creative capabilities.
                Designed for creativity - just the right toolsThe innovative Wacom Intuos Pro pen tablet combines Wacom's finest pen capabilities and intuitive multi-touch gestures. It gives you the power to produce professional results with the precision and control you demand from your professional software. Designed for creative work, it delivers a natural and intuitive experience that extends your creative capabilities.
                Your endless creative toolbox2048 levels of pen pressure sensitivity and tilt recognition let you create with the accuracy and precision of traditional brushes, pens and markers, while multi-touch gestures allow you to position and navigate your work intuitively.
                Stay focused and enjoy the creative experienceGet the most from your creative software with your favorite pre-selected shortcuts. The Intuos Pro even detects the software you're using and offers optimal selections. Quickly access all your shortcuts through the customizable ExpressKeys and Touch Ring. Stay focused with the Express View display and Radial Menu. Discover intuitive navigation at the touch of your fingers: pan, zoom, rotate and navigate naturally with gestures, or create your own multi-touch shortcuts.
                Enjoy wireless flexibility and ergonomicsCut down on cord clutter and enjoy the freedom of creating wirelessly. Intuos Pro is designed ergonomically for both right and left hand use, so you'll be comfortable all day.
- Wacom Intuos Pro Medium - Paper Edition - digitiser - USB, Bluetooth - black
- Digitiser
- Connectivity Technology
- Wireless, wired - USB, Bluetooth
- Black
- Orientation
- Right and left-handed
- 33.8 cm x 21.9 cm x 0.8 cm
- 700 g
- Multi-Touch
- Movement Detection Technology
- Electromagnetic
- Buttons Qty
- 8
- Movement Resolution
- 5080 lpi
- Programmable buttons, pressure sensitivity, finger-sensitive Touch Ring, soft rubber grip, ExpressKeys, -/+ 60 levels tilt recognition
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
- 2-year warranty
- Digitiser
- Orientation
- 33.8 cm
- 21.9 cm
- 0.8 cm
- 700 g
- Black
Input Device
- Wireless, wired
- Interface
- USB, Bluetooth
- Electromagnetic
- Multi-Touch
- Buttons Qty
- 8
- 5080 lpi
- Pressure Levels
- 8192
- Active Area
- 22.4 cm x 14.8 cm
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Pen stand, nibs (10 pcs.), stylus pen, USB cable (2 m), 4 interchangeable colour rings, accessories case, finetip pen, 10 paper sheets, 3 finetip ink refills, texture sheet sample card
- VCCI, IC, RoHS, URSEC, CEC, SRRC, iDA, China RoHS, RCM, SIT, Telcor, SITTEL, INDOTEL, TATT, SUTEL, RBRC
- OS Required
- Limited warranty - 2 years
