The Intuos4 Classic Pen has the same feature set as the standard Intuos4 Grip Pen but with a slimmer profile. With its optimum weight and balance it fits perfectly in your hand. Its unique design and pressure and tilt sensitivity make it the perfect freehand tool - for fatigue-free work over long periods.
Its ergonomic waisted grip area is equipped with the Double Side Switch and the pressure sensitive eraser. With tool ID you can assign every Intuos4 pen to each of your favorite brushes in supporting software just swap pens to switch between software brushes.
- Wacom Classic Pen - active stylus
- Active stylus
- 15.1 cm x 1.2 cm x 1.6 cm
- 12 g
- Eraser, pressure sensitivity, tilt sensitive
- Designed For
- Cintiq 21UX; Intuos4 Large, Medium, Small, Wireless, X-Large
- Active stylus
- 15.1 cm
- 1.2 cm
- 1.6 cm
- 12 g
Input Device
- Pressure Levels
- 2048
- Included Accessories
- Pen stand, nibs (4 pcs.)
- Designed For
- Wacom Cintiq 21UX , Wacom Intuos4 Large, Medium, Small, Wireless, X-Large
