The Cintiq Ergo Stand offers a range of ergonomic options for the natural feel of working on an easel or drafting table. The ergonomically designed, counterweighted stand allows you to quickly and effortlessly adjust the incline and height of the display to your favorite working position. Place it at the edge of your desk or work while standing, whatever is most comfortable for you. It's designed for both Cintiq 27QHD creative pen displays, model numbers DTK2700 and DTH2700.
- Wacom digitizer stand
- Product Type
- Digitizer stand
- 82 cm x 51 cm x 39 cm
- 16 kg
- Designed For
- Cintiq 27QHD, 27QHD Touch
- Product Type
- Digitizer stand
- 82 cm
- 51 cm
- 39 cm
- 16 kg
- Adjustable height
- Designed For
- Wacom Cintiq 27QHD, 27QHD Touch
