The Cintiq 27QHD creative pen displays set a new standard in color and resolution. The most natural form of creative expression meets an advanced interface design that re-imagines the creative workflow so you don't have to adapt to the tool - the tool adapts to you. Work with hands-on fluidity as you create with a pressure-sensitive pen directly on an expansive, edgeless glass display.
The Cintiq 27QHD's 27" widescreen 16:9 display offers the highest resolution of any Cintiq (2560 x 1440). Featuring 97% Adobe RGB, 1.07 billion colors and REC 709, this premium color display is the ultimate tool for color sensitive workflows.
The ExpressKey Remote can be positioned anywhere on the screen for a faster, more flexible workflow. Customize the ExpressKeys on the remote with your favorite shortcuts, and use the Touch Ring to zoom, rotate or change brush sizes. Spend less time searching for the correct shortcut and more time getting lost in your ideas.
Choose your working position and stand: Place the Cintiq 27QHD on your desk for either a 5° slope or foldout the sturdy legs for a 20° angle.
The Cintiq 27QHD Pro Pen features Wacom's proprietary Tip Sensor technology, which offers users near-zero (one gram) starting pressure and virtually the same natural experience as one working with traditional brushes or pens. The pen also features a pressure-sensitive eraser and two side switches that can be customized for common commands, such as double-click and right-click. The pen includes 2048 levels of pressure sensitivity and 40° pen tilt recognition.
Compatible with both Mac and PC platforms, the Cintiq 27QHD works seamlessly with your computer's configuration, including another Cintiq, an Intuos pen tablet, or your existing mouse.
It takes millions of pixels to make colors look this sharp
The Cintiq 27QHD offers true-to-life color on a high-resolution display giving you unparalleled clarity and color sensitivity in creative areas like image editing and 3D animation. -
Pen-on-paper feel
A professional grade creative pen and a highly responsive glass screen that's finished to provide the friction of a natural pen-on-paper feel. -
Spend more time creating
The ExpressKey Remote encourages a faster, more flexible workflow with a Touch Ring that helps you scroll, zoom and rotate with ease. Put it on the screen, beside your keyboard or right in your hand. Spend less time searching for what you need and more time getting lost in your ideas. -
A complete toolbox in the palm of your hand
Whether you want the precision of a fine line pen or the texture of broad brush strokes, the included Pro Pen has you covered. With a range of available nibs, including felt for a smooth flow across the tablet surface, it's all your favorite artistic tools in one powerful pen.
- Wacom Cintiq 27QHD - digitiser - USB - black
- Digitiser
- Connectivity Technology
- Wired - USB
- Display
- LCD display - 27" - 2560 x 1440
- Black
- 77 cm x 46.5 cm x 5.45 cm
- 9 kg
- Localisation
- Canada, United States
- Pressure sensitive pen, eraser, finger-sensitive Touch Ring, tilt sensitive, ExpressKeys
- Power
- AC 120/230 V
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.8 or later
- 2-year warranty
- Digitiser
- 77 cm
- 46.5 cm
- 5.45 cm
- 9 kg
- Black
- Localisation
Input Device
- Wired
- Interface
- USB
- Pressure Levels
- 2048
- Active Area
- 51.84 cm x 32.4 cm
Display
- LCD display
- Diagonal Size
- 27"
- Image Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Native Resolution
- 2560 x 1440
- 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - DisplayPort - 20 pin DisplayPort , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A
- Included Accessories
- Pen stand, stand, nibs (10 pcs.), remote control, USB cable, AC power adapter, Mini DisplayPort to DisplayPort adapter, DVI-D to HDMI Cable adapter, DisplayPort cable, HDMI cable
- Voltage Required
- AC 120/230 V
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
