Work directly on the 54.6 cm (21.5") display with 1920 x 1080 pixel resolution and gain superior control over your workflow through natural pen input combined with multi-touch functionality.
Be versatile, flexible and more productive
If you like to sketch, draw, or paint digitally, working with the Cintiq 22HD touch will bring your creative productivity to a new level. -
Extend your senses - and turn the screen into your canvas
With 1920 x 1080 pixel resolution and 16.7 million colors, you can treat the 54.6 cm (21.5") Full HD display more as a canvas than as a screen. Wacom's advanced, pressure-sensitive pen, combined with the Cintiq 22HD's intuitive, multi-touch capabilities, and delivers a seamless and truly natural creative experience. -
Have more flexible control - with multi-touch input
Enjoy the precise, intuitive control of on-screen creation with Wacom's pressure-sensitive pen while using multi-touch gestures to position and navigate your work. -
Turn and twist your screen - digitally and for real
The Cintiq 22HD touch's ergonomic stand offers both landscape and portrait viewing angles. Adjust it easily to your preferred working position so you can work in complete comfort. -
Believe it when you see it
The Cintiq 22HD touch offers so many innovations that, with the advanced, pressure-sensitive pen, its range of features comes together into a truly hands-on creative and productive experience.
- Wacom Cintiq 22HD Touch - digitiser - USB
- Digitiser
- Connectivity Technology
- Wired - USB
- Display
- LCD display - 21.5" - 1920 x 1080
- 65 cm x 40 cm x 6.75 cm
- 8.4 kg
- Movement Detection Technology
- Electromagnetic
- Buttons Qty
- 16
- Movement Resolution
- 5080 lpi
- Pressure sensitive pen, eraser, multi-finger touchpad, multi-touch digitiser, ExpressKeys
- Cables Included
- 1 x USB cable - external , 1 x DVI cable - external
- Power
- AC 120/230 V
- OS Required
- Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.6.8 or later, Windows 8
- 3-year warranty
- Digitiser
- 65 cm
- 40 cm
- 6.75 cm
- 8.4 kg
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- Buttons Qty
- 16
- 5080 lpi
- Pressure Levels
- 2048
- Active Area
- 47.9 cm x 27.1 cm
Display
- LCD display
- Diagonal Size
- 21.5"
- Pixel Pitch
- 0.25 mm
- Colour Support
- 16.7 million colours
- Native Resolution
- 1920 x 1080
- Image Brightness
- 210 cd/m²
- Image Contrast Ratio
- 900:1
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Response Time
- 14 ms
- 1 x USB 2.0 - 4 pin USB Type A , 1 x display / video - DVI-Digital
- Included Accessories
- Stand, nibs (10 pcs.), adjustable display stand
- Cables Included
- USB 2.0
- Power adapter
- Voltage Required
- AC 120/230 V
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 3 years
Wacom Cintiq 22HD Touch Black USB DVI VGA Graphics Tablet
