Wacom Cintiq 21UX
Wacom Cintiq 21UX
Quicklinx: 70ZJWS00 Mfr#: DTK-2100
The Cintiq 21UX interactive pen display provides the best-of-class pen experience for working directly on the screen. It combines the advantages of a large-format LCD monitor with the control, comfort, and productivity of Wacom's most sophisticated patented cordless, battery-free pen technology.
With a 21.3" TFT diagonal display, the Cintiq 21UX delivers a highly sensitive pen-on-screen experience and a generous active area for working directly on large images, concepts, and designs in the most natural way possible. Working directly with the pen on screen is a natural motion that gives you an unprecedented degree of control and allows you to take advantage of natural hand-eye coordination, helping you work more intuitively and noticeably faster.
The display's completely flat surface allows the hand and pen to glide over the surface of the Cintiq without bumping into any bezels or borders. A dynamically-adjustable stand allows you to rotate the display up to 180° in each direction, incline the display from 10° to 65°, and even removes it for comfortable lap use. Rear roller feet make the incline adjustments easy; the result is freedom to adjust the interactive display to positions that work for you.
Strategically-placed ExpressKeys and touch strips are programmable, allowing you to customize your Cintiq to your needs. The ExpressKeys are easily accessible on either side of the display and provide quick access to keyboard shortcuts, modifier keys, and functions that minimize dependence on the keyboard for uninterrupted work sessions. Finger-sensitive touch strips are located on either side of the display for easy zooming, scrolling, or making tool adjustments without taking focus away from the pen tip.
Wacom Cintiq 21UX - digitiser - USB
Digitiser
Wired - USB
Display
LCD display - 21.3" - 1600 x 1200
56.1 cm x 42.1 cm x 4.8 cm
8.7 kg
Movement Detection Technology
Electromagnetic
Buttons Qty
8
Movement Resolution
5080 dpi
Accuracy
± 0.5 mm
Programmable buttons, pressure sensitive pen, eraser, tilt sensitive
1 x data cable - integrated , 1 x DVI-VGA adapter - external , 1 x DVI adapter - external
AC 120/230 V
Apple MacOS X 10.4.1 or later, Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Certified for Windows Vista
Digitiser
56.1 cm
42.1 cm
4.8 cm
8.7 kg
Input Device
Wired
USB
Electromagnetic
Buttons Qty
8
Movement Resolution
5080 dpi
Accuracy
± 0.5 mm
Pressure Levels
2048
Active Area
43.2 cm x 32.4 cm
Display
LCD display
Diagonal Size
21.3"
Pixel Pitch
0.27 mm
Colour Support
16.7 million colours
Native Resolution
1600 x 1200
Image Brightness
220 cd/m²
Image Contrast Ratio
550:1
Horizontal Viewing Angle
170
Vertical Viewing Angle
170
Response Time
20 ms
Backlight Life
30,000 hour(s)
1 x USB - 4 pin USB Type A , 1 x display / video - DVI-Analog/Digital
Pen stand, stand, nibs (10 pcs.)
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
VCCI, C-Tick, BSMI, ISO 13406-2, FCC, KCC
Power adapter
AC 120/230 V
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM
5 °C
35 °C
20 - 80%
