The third-generation Bamboo Stylus duo gives you smooth performance on screen and on paper - with a unique and responsive carbon fiber nib and a high-quality ball point. It is both extremely practical and stylish. With an elegant premium design, it perfectly matches your individual style. Due to their clean curvature shape and their satined aluminum finish, they actually feel as good as they look. The unique, highly durable carbon fiber nib ensures a supremely fluid writing experience on touch screens. And should the nib ever wear out after extensive use, you can easily replace it. Compatible with media tablets, smartphones and PCs with capacitive touch screens.
Versatile design
Designed for both cellular phones and tablets, the Wacom Bamboo Duo 3Gen offers a dual-functionality that makes it a perfect companion for your digital and traditional writing needs. Its stylus tip allows for precise navigation on touchscreens, while the black ink ballpen is ideal for jotting down notes on paper. -
Elegant construction
Crafted from high-quality aluminum, the Wacom Bamboo Duo 3Gen boasts a sleek, durable design. The pen-like pocket clip ensures it can be easily carried in a pocket or attached to a notebook, making it as portable as it is stylish.
- Wacom Bamboo Duo 3Gen - stylus / ballpen for mobile phone, tablet
- Product Type
- Stylus / ballpen
- Intended For
- Mobile phone, tablet
- Product Material
- Aluminium
- 0.9 cm
- Length
- 13 cm
- 14.1 g
- Orange
- Product Type
- Stylus / ballpen
- Intended For
- Product Material
- Aluminium
- 0.9 cm
- Length
- 13 cm
- 14.1 g
- Orange
- Pen-like pocket clip, black ink ballpen, carbon fibre tip
