The second generation Bamboo Stylus duo gives you excellent performance both on screen and on paper - thanks to a very slim and responsive rubber nib and a ball point with a high-quality ink refill. So you can conveniently switch between your paper notebook and your touchscreen device.
But a Bamboo Stylus duo is not only extremely practical, it also convinces with its stylish, clean-lined design and select materials: the soft-touch finish body feels comfortable in the hand and the cap of polished anodized aluminum is an elegant accent. And then there are six chic color options - so you can choose if you want to impress or if a more subtle color suits you better.
A Bamboo Stylus is made of high-quality materials and crafted with care. That makes it a long-living fellow. And when the rubber nib - finally - wears off after extensive use, you can replace it as easily as the ink refill.
- Wacom Bamboo Duo 2Gen - stylus / ballpen
- Product Type
- Stylus / ballpen
- Product Material
- Metal
- 0.84 cm
- Length
- 13.3 cm
- 16.2 g
- Black
- Product Type
- Stylus / ballpen
- Product Material
- Metal
- 0.84 cm
- Length
- 13.3 cm
- 16.2 g
- Black
- Rubber nib, pen-like pocket clip
