The PPS 800 projector mount is specially designed for the new generation short throw projectors up to 10kg. This wall mount has unique features for short throw applications and is fitted with a universal adapter.
The PPS 800 wall mount is especially designed for the new generation short throw projectors. This wall mount has unique features especially for short throw applications and will save a lot of installing and adjustment time. On top of that this wall mount has a stylish design and a lightweight aluminum construction.
- Vogel's PPS 800 - mounting kit - for projector - silver
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Short throw wall mount
- Adjustments
- Tilt
- 9.8 kg
- Recommended Use
- Projector
- Max Load Weight
- 15 kg
- Silver
- 5-year warranty
- 9.8 kg
- Silver
AV Furniture
- Mounting kit
- Recommended Use
- Projector
- Placing / Mounting
- Wall-mountable
- Adjustments
- Tilt
- Max Load Weight
- 15 kg
- Adjustable height, adjustable depth, Fine Tune Mechanism (VFT), horizontal shift
- Limited warranty - 5 years
