Vogels EFF1140 LCD Floor Stand
Quicklinx: 4FCBWS00 Mfr#: EFF1140/SI
The EFF 1140 is a universal support and can be placed easily anywhere you want. It offers an optimal viewing position by the turn function. The cables can be cleverly concealed with the unique Vogel's Cable Inlay System. The A/V support can be adjusted in height and dept to fit different sized equipment.
Vogel's Evolution EFF 1140 stand - for flat panel / DVD / audio - silver, aluminium
Stand - floor-standing
70 cm x 34.6 cm x 111.3 cm
11.9 kg
Recommended Use
Flat panel / DVD / audio
Recommended Display Size
25"-42"
Max Load Weight
45 kg
Silver, aluminium
70 cm
34.6 cm
111.3 cm
11.9 kg
Silver, aluminium
AV Furniture
Stand
Recommended Use
Placing / Mounting
Floor-standing
Shelf Qty
1
25"-42"
Max Load Weight
45 kg
Rotating, height adjustable shelves, Cable Inlay System (CIS)
