Vodafone Sure Signal creates a 3G signal - ideal if you live in the countryside or a basement flat where it's difficult to get good reception. As it fits straight into a plug socket, Sure Signal doesn't take up much space in your home or small office. You can easily hide it away - and as it has an extra plug, you won't lose a socket either.
Fits in easily
As it fits straight into a plug socket, Sure Signal doesn't take up much space in your home or small office. You can easily hide it away - and as it has an extra plug, you won't lose a socket either. -
Get up to eight people online at the same time
You can register up to 32 numbers on your Vodafone Sure Signal, and up to eight devices can connect at once. Perfect if you have a large family, and more than one of you wants to make a call. -
Broadband Internet
Because Sure Signal works through your broadband Internet, it can create a 3G signal even in areas with no reception. Although it works with the majority of broadband providers and most routers, not all are compatible.
- Vodafone Sure Signal - white - 3G fixed cellular terminal - UMTS
- Product Type
- Service Provider
- Vodafone
- White
- Product Type
- Fixed cellular terminal
- Body Colour
- White
Cellular
- Technology
- WCDMA (UMTS)
- Mobile Broadband Generation
- 3G
- Service Provider
- Vodafone
Phone Features
- Additional Features
- Access Control List
