By using low-impedance digital amplifier chip technology the Techconnect AMP2 module outputs a massive 2 x 20w RMS (at 8 ohms) but fits into the space of a Techconnect module.
Digital amplifiers use no power unless they are amplifying program, so even on at full volume; unless it is receiving input it is effectively off. Digital amplifiers also have the advantage of running cold so a bulky heatsink is not necessary but don't let size deceive you: the Techconnect AMP2 can drive into a 4 ohm load allowing you to power up to four speakers.
A clear display makes the product easy to use and a simple soft-control interface gives instant access to controls. Because the control panel can be installed anywhere in the room it is more convenient than traditional powered speakers where access to the controls can be awkward.
Quick-access input
Two inputs are wired into the rear with removable phoenix connectors, however a feature of this amplifier is that input 1 is duplicated on the front panel with a mini jack socket for convenience. -
Green D-Class amplifier
Digital amplifiers use no power unless they are amplifying program, so even on at full volume; unless it is receiving input it is effectively off. Digital amplifiers also have the advantage of running cold so a bulky heatsink is not necessary but don't let size deceive you: the Techconnect AMP2 can drive into a 4 ohm load allowing you to power up to four speakers. -
LED display
A clear display makes the product easy to use and a simple soft-control interface gives instant access to controls. Because the control panel can be installed anywhere in the room it is more convenient than traditional powered speakers where access to the controls can be awkward. -
Easy to install and uninstall
Vision has paid special attention to creating a robust product that is simple and easy to install; the inputs and outputs are all via removable phoenix connectors which allow non-technical end users to uninstall it very easily if required. Short input cables are included for connection to the rear of adjacent input modules on the Techconnect. -
Wall mounted and secure
Ideal when you don't have furniture to sit an amplifier on, and because it is mounted to the wall it is much less obvious as a target for theft. It is close at hand if volume adjustments need to be made, making it perfect for training rooms, boardrooms, and classrooms. -
Laptop-style power supply
A DC tail which can be shortened means easy routing of power cable through trunking. Velcro is included for fixing the power supply in place, or a blank surround is available to hide it in a standard.
- Vision Techconnect TC2-AMP2 - amplifier
- Product Type
- Amplifier
- Enclosure Colour
- White
- Audio Channels
- Stereo
- Audio Specifications
- Amplifier - 80 - 22000 Hz - 98 dB
- Frequency Response
- 80 - 22000 Hz
- Output Power
- 40 Watt
- Display
- LED display
- Remote Control
- Remote control
- Power
- AC 120/230 V (50/60 Hz)
- 4.2 cm x 4 cm x 7.1 cm
- 63 g
- 2-year warranty
- Product Type
- Amplifier
- Enclosure Colour
- White
Audio System
- Audio Channels
- Stereo
- Functions
- Amplifier
- Amplifier - Response Bandwidth - 80 - 22000 Hz - SNR - 98 dB
- 80 - 22000 Hz
- Signal-To-Noise Ratio
- 98 dB
- Output Power / Total
- 40 Watt
- Input Impedance
- 50 kOhm
- Input Sensitivity
- 500 mV
- Total Harmonic Distortion
- 1.0%
- Amplifier Output details
- 20 Watt - 8 Ohm - 2 channels (main)
Display
- Display Type
- LED display
Remote Control
- Remote control
- Connectors
- 2 x audio line-in , Speakers output
- Included Accessories
- AC power adaptor, audio cable, remote control, speaker cable
- Cables Included
- 2 x speaker cable - 5 m , 2 x audio cable - 15 cm
- Power Device
- Power adapter - external
- Voltage Required
- Limited warranty - 2 years
- 4.2 cm
- 4 cm
- 7.1 cm
- 63 g
- Width (Shipping)
- 23 cm
- Depth (Shipping)
- 6.3 cm
- Height (Shipping)
- 10 cm
- Weight (Shipping)
- 1 kg
