Your basket is empty
Vision TM-ST2 Short Throw Mount
Quicklinx: 9K6TWS00 Mfr#: TM-ST2
Hurry, only 1 left in stock!
£78.75 ex VAT
£94.50 inc VAT
Express delivery Delivered on Tuesday
The Techmount ST2 supports 99% of short-throw and ultra-short-throw projectors with no extra parts required. It is a strong, flexible mount which uses Vision's universal spider fitting to attach projectors.
Vision Techmount TM-ST2 - mounting kit (telescopic)
Mounting kit (telescopic)
Mounting Components
Wall bracket, pole
Tilt
Recommended Use
Projector
Satin white
Satin white
AV Furniture
Mounting kit
Mounting Components
Wall bracket, pole
Design
Telescopic
Recommended Use
Projector
Tilt
Adjustable height, adjustable depth
Brand: Vision
Price Range Ex VAT: 50 - 100
