Your basket is empty
Vision TM-IFP Portable Conversion Kit
Quicklinx: 9K6RWS00 Mfr#: TM-IFP WHEELS
More than 50 in stock
£211.25 ex VAT
£253.50 inc VAT
If the flat-panel is a shared resource Vision offer a dolly which converts the assembly into a portable solution. The weighted base is 950mm wide by 660mm deep and uses big 100mm wheels to maximize stability.
Vision - mounting component
Mounting component
Mounting Components
Weighted base
95 cm x 66 cm
13 kg
Wheels Qty
4
95 cm
66 cm
13 kg
AV Furniture
Mounting component
Mounting Components
Weighted base
Wheels Qty
4
Wheel Diameter
10 cm
Brakes Qty
4
Brand: Vision
Price Range Ex VAT: 150 - 300
