Enhanced durability
Featuring a braided design with a ferrite core, the Vision Techconnect 2 USB cable is built for enhanced durability and reduced electromagnetic interference, ensuring a stable connection. -
High-quality connectivity
Gold-plated connectors on both ends of the cable not only resist corrosion but also provide an optimal signal transfer for clear and reliable data transmission. -
Flexible design
Designed with flexibility in mind, this USB cable can easily bend to fit tight spaces without compromising the integrity of the cable, making it ideal for complex setups.
- Vision Techconnect 2 - USB cable - USB Type B to USB - 5 m
- USB cable
- Technology
- Shielded
- Braided, flexible, ferrite core
- Length
- 5 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- White
- Limited lifetime warranty
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Gold
- Length
- 5 m
- White
- Connector
- USB / USB 2.0
