Vision TechConnect 5m USB Cable
Quicklinx: 9K9SWS00 Mfr#: TC2 5MUSB
Length: 5m
More than 50 In Stock
£11.38 ex VAT
£13.65 inc VAT
Marketing description is not available.
  • Enhanced durability
    Featuring a braided design with a ferrite core, the Vision Techconnect 2 USB cable is built for enhanced durability and reduced electromagnetic interference, ensuring a stable connection.
  • High-quality connectivity
    Gold-plated connectors on both ends of the cable not only resist corrosion but also provide an optimal signal transfer for clear and reliable data transmission.
  • Flexible design
    Designed with flexibility in mind, this USB cable can easily bend to fit tight spaces without compromising the integrity of the cable, making it ideal for complex setups.
Vision Techconnect 2 - USB cable - USB Type B to USB - 5 m
USB cable
Shielded
Braided, flexible, ferrite core
Length
5 m
Connector
4 pin USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
White
USB cable
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Gold
Length
5 m
White
Connector
USB / USB 2.0
Length: 5m
Brand: Vision
