Your basket is empty
Vision AV-1700 Stereo Amplifier
Quicklinx: 9C08WS00 Mfr#: AV-1700
More than 50 in stock
£103.53 ex VAT
£124.23 inc VAT
The Techaudio AV-1700 is compact, flexible, easy to use and is extremely efficient. Use as a standalone mixer and amp, or as a mixer which outputs to a bigger amp or powered loudspeakers.
Vision Techaudio AV-1700 - amplifier
Amplifier
Enclosure Colour
White
22 cm x 15.4 cm x 4.4 cm
1.2 kg
Sound Output Mode
Stereo
Audio Specifications
Amplifier - 50 - 18000 Hz - 75 dB 2%
AC 120/230 V
2 years warranty
Amplifier
22 cm
15.4 cm
4.4 cm
1.2 kg
Enclosure Colour
White
Audio System
Sound Output Mode
Stereo
Functions
Amplifier
Amplifier - Response Bandwidth - 50 - 18000 Hz - SNR - 75 dB - THD - 2%
Input Impedance
47 kOhm
Input Sensitivity
500 mV
Amplifier Output details
30 Watt - 8 Ohm - 2 channels (main) , 60 Watt - 4 Ohm - 2 channels (main)
Bass Control
Treble Control
Connector Type
1 x audio line-in (mini-phone stereo 3.5 mm) - rear , 3 x audio line-in (RCA x 2) - rear , 1 x audio line-out (RCA x 2) - rear , 1 x serial - rear , 2 x speakers output - rear , 1 x microphone (XLR) - rear
Remote control, 2 audio cables, 4 power cables, 2 speaker cables (5 m)
AC 120/230 V
125 Watt
Width (Shipping)
29.3 cm
Depth (Shipping)
23.3 cm
Height (Shipping)
13.3 cm
Weight (Shipping)
2 kg
Brand: Vision
Price Range Ex VAT: 100 - 150
