Vision AUDIO BUNDLE - TECHCONNECT2 AMPLIFIER + BLACK SP-1300
Quicklinx: 7VLFWS00 Mfr#: TC2-AMP2+SP-1300B
By using latest low-impedance digital amplifier chip technology the Techconnect Amp2 module outputs a massive 2 x 20w RMS (at 8 ohms) but fits into the space of a Techconnect module.
Attractive and discreet; the Vision wall speakers offer clear, powerful audio reinforcement in a compact form factor. The SP-1300 has a warm, well-rounded bass, with smooth high frequencies that extend beyond 20kHz. Match these to a low-impedance amplifier and be amazed how big they sound!
  • TC2-AMP2 FEATURES:
    Quick-access inputTwo inputs are wired into the rear with removable phoenix connectors, however a feature of this amplifier is that input 1 is duplicated on the front panel with a minijack socket for convenience. This half-normalled input disconnects the rear terminal while in use.
  • Green D-class amplifier
    Digital amplifiers use no power unless they are amplifying program, so even on at full volume; unless it is receiving input it is effectively off. Digital amplifiers also have the advantage of running cold so a bulky heatsink is not necessary... but don't let size deceive you: the Techconnect Amp2 can drive into a 4 ohm load allowing you to power up to four speakers.
  • LED display
    A clear display makes the product easy to use and a simple soft-control interface gives instant access to controls. Because the control panel can be installed anywhere in the room it is more convenient than traditional powered speakers where access to the controls can be awkward.
  • Remote control included
    IR receivers are positioned on the front for normal use and on the rear for integration with a control system such as the Techconnect Control2.
  • Easy to install and uninstall
    Vision has paid special attention to creating a robust product that is simple and easy to install; the inputs and outputs are all via removable phoenix connectors which allow non-technical end users to uninstall it very easily if required. Short input cables are included for connection to the rear of adjacent input modules on the Techconnect.
  • Wall mounted and secure
    Ideal when you don't have furniture to sit an amplifier on, and because it is mounted to the wall it is much less obvious as a target for theft. It is close at hand if volume adjustments need to be made, making it perfect for training rooms, boardrooms, and classrooms.
  • Integrated Techconnect family
    Included is a single-gang backbox and surround, or alternately you can mount the amplifier module in a double-gang surround with other Techconnect modules. You could even mount this module into a Techconnect Tilt in the table.
  • Laptop-style power supply
    A 3m DC tail which can be shortened means easy routing of power cable through trunking. Velcro is included for fixing the power supply in place, or a blank surround is available to hide it in a standard double-gang UK backbox.
  • SP-1300 FEATURES:
    Wall bracket includedSturdy brackets with easy adjustment are included. With flexible mounting options to allow installers to arrange the loudspeakers evenly throughout the room, the ball-joint bracket allows exact positioning to create an expansive stereo image. If the speaker is white chances are you'll want white brackets too, so our white speakers come with white brackets.
  • High definition
    Vision has over specified all the components in the passive crossover to ensure a smooth low-mid range response. The 4? lower cone is dedicated to bass and mid, which gives clearer, crisper midrange than you might normally find in smaller speakers. The silk dome tweeter adds needle-sharp top end all the way to 20kHz and beyond. The 86dB sensitivity belies that more effort has gone into making these loudspeakers sound good, rather than just being outright loud.
Header / Manufacturer
Vision
Header / Model
Techconnect TC2-AMP2 w/ SP-1300
Sound Output Mode
Stereo
Audio System / Components
Speaker system
Remote Control / Type
Remote control
Miscellaneous / Colour
Audio System / Subcategory (KA)
Audio systems, radios, karaoke
Audio System Type
Audio system
Audio System / Functions (KA)
Amplifier
Amplifier / Output Power / Total
40 Watt
Header / Packaged Quantity
1
