Frameless bezel design
Break free from bulky designs, and prepare for a frameless experience. An ultra slim 6.6 mm panel and a thin 2 mm bezel, delivering an incredible visual experience. -
Stunning color performance & wide-angle viewing
With SuperClear IPS panel technology, enjoy accurate and vivid colors with consistent levels of brightness whether you are looking at the screen from above, below, the front, or the side. -
Full HD 1080p resolution
This monitor features Full HD 1920x1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether while working, gaming, or enjoying the latest in multimedia entertainment. -
Flexible connectivity
HDMI, DisplayPort and VGA inputs, enable users to connect to game consoles, Blu-ray players, digital cameras, laptops, satellite boxes, and other high-definition devices. -
Enhanced viewing comfort
Flicker-Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods.
- ViewSonic VX2476-smhd - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 31 kWh
- Power Consumption (On mode)
- 21 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Silver
- 54 cm x 20.9 cm x 41.4 cm
- 2.97 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, ICES-003, WEEE, cULus, EAC, NRCAN, Mexico Energy label, Mexico CoC, Energy Efficiency Label (EEL)
- (Austria, Germany, Switzerland - 2 years)
- Display Type
- Energy Class
- Class A
- 31 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- SuperClear, game mode, Flicker Free technology, Blue Light Filter technology, Wide Viewing Angle, Movie Mode, text mode, web mode, mono mode, frameless bezel design, Low Input Lag
- Silver
- 54 cm x 20.9 cm x 41.4 cm - with stand
- 2.97 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- HDMI , DisplayPort , VGA , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+17
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 21 W
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- Without stand - width: 54 cm - depth: 3.4 cm - height: 32.3 cm - weight: 2.53 kg , With stand - width: 54 cm - depth: 20.9 cm - height: 41.4 cm - weight: 2.97 kg
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
