ViewSonic VX2452MH 23.6" 1920x1080 2ms VGA DVI-D HDMI LED Monitor
Quicklinx: 94SRWS00 Mfr#: VX2452MH
ViewSonic's VX2452MH is a 24" (23.6" viewable) Full HD, glossy-finish display that offers the ultimate visual experience for gaming and multimedia entertainment. The VX2452MH features ClearMotivII technology that delivers 2 ms ultra-fast response time for blur-free images during extreme gaming, and an ultra-high 50M:1 MEGA dynamic contrast ratio for sharp, crisp color performance for enjoying movies. Integrated D-sub, DVI and HDMI inputs provide flexible connectivity for high-definition multimedia devices and gaming consoles, and dual built-in 2-watt stereo speakers complete the package for multimedia enjoyment. With a VESA-mountable design, the VX2452MH offers flexible mounting options for any of your gaming and video entertainment needs.
  • Blazing-fast response time for blur-free action
    ViewSonic's exclusive ClearMotiv II imaging technology delivers ultra-fast 2 millisecond liquid crystal response times, creating smooth images without streaking, blurring or ghosting. This blazing-fast response time is perfect for the most graphic-intense gaming needs, and just as great for watching sports or action movies. Enjoy blur-free digital broadcasts and full-motion graphics
  • Stunning resolution and clarity
    The VX52 series of displays feature Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while gaming or enjoying the latest in multimedia entertainment.
  • Game mode
    ViewSonic's game mode provides heightened visibility and detail by brightening dark scenes. Dominate the competition with enhanced visibility, even in the darkest scenes of a video game. With just the press of a button, ViewSonic's game mode delivers superior color performance for the ultimate gaming experience.
  • MEGA dynamic contrast ratio for sharp, crisp images
    A superior dynamic contrast ratio of 50M:1 better defines the relationship between the darkest and brightest colors, ensuring all displayed images are rich and detailed.
  • Flexible HDMI connectivity
    HDMI is the highest, future-proof video standard, guaranteed for true digital picture clarity. The HDMI interface on the VX2452MH allows you to connect to a variety of HD devices including gaming consoles, Blu-ray players, laptop PCs, digital cameras, and many others for the ultimate true high-definition experience.
  • ENERGY STAR certified and mercury-free LED backlighting
    LED backlighting enhances display performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images. The LED backlighting further conserves up to 25% more energy when compared to conventional displays. In addition, a slim, lightweight profile saves desktop space.
  • Eco-mode conserves more energy
    ViewSonic's proprietary eco-mode function comes standard with the VX2452MH display. It offers 85% and 75% "optimize" and "conserve" modes based on the users' working scenarios. Both modes reduce display brightness and conserve energy by up to 25%. In low ambient lighting, this function adjusts brightness to improve visibility and reduce eye fatigue. Eco-mode prolongs the monitor's lamp life, improving your return on investment.
  • Dual integrated 2 W speakers
    The VX2452MH has two integrated speakers for enhanced multimedia performance with crystal-clear stereo sound.
  • VESA-mountable design
    The VX2452MH features a 100 x 100 mm VESA-mountable design that allows you to mount the display on a monitor stand or on a wall, depending on your specific needs. You can easily detach the base by unscrewing four screws and then mounting the display on its stand or wall mount.
ViewSonic VX2452MH - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
55.92 cm x 22.25 cm x 43.17 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, NOM, SASO, TUV S, CB, CCC, PSB, RoHS, WEEE, GOST-R, UkrSEPRO, ERP, SVHC
3-year warranty
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
HDCP, Eco-Mode, ClearMotiv II, game mode, Mega Dynamic Contrast Ratio, a-Si technology
55.92 cm x 22.25 cm x 43.17 cm - with stand
3.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI (HDCP) , DVI-D (HDCP) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Power Supply
External
Input Voltage
Power Consumption (Typical)
21.5 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 55.92 cm - depth: 22.25 cm - height: 43.17 cm - weight: 3.8 kg , Without stand - width: 55.92 cm - depth: 5.3 cm - height: 35.67 cm - weight: 3.5 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 90% (non-condensing)
