With future-proof connectivity and advanced ergonomics, the ViewSonic VG2753 is a productivity-boosting monitor perfect for corporate, government, and education environments. Designed with SuperClear IPS panel technology for wide-angle viewing and incredibly vivid colors, this monitor also features a 3-sided thin-bezel design for a seamless viewing experience in multi-monitor setups. For maximum comfort and a customized fit, a robust fully ergonomic stand gives you tilt, pivot, swivel, and height-adjustable options. In addition, VDI client endpoints can be easily attached to the stand’s integrated client mount, saving desktop space and minimizing cable clutter without interfering with ergonomic functionality. Extensive connectivity options include VGA, HDMI, DisplayPort, and Mini DisplayPort so that you can connect to a variety of HD and analog devices – today and tomorrow.
Ultra-wide viewing angles
Enjoy accurate and vivid colors with consistent levels of brightness no matter the vantage point. With SuperClear IPS panel technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side. -
Frameless design
A premium panel delivers accurate colors and vivid images, while a frameless design provides for a nearly seamless viewing experience in multi-monitor setups. And with ultra-wide viewing angles, you'll enjoy stunningly detailed images, unbound and without borders, no matter your vantage point. -
Versatile connectivity
DisplayPort, HDMI, and VGA inputs give you the freedom to connect your display to a variety of devices. -
Ergonomic design
With advanced ergonomic features, ViewSonic monitors are designed to provide a greater range of adjustment for increased productivity and comfort. Users can reduce eyestrain and physical fatigue by adjusting the monitor via swivel, pivot, tilt, and height adjust options. -
Full HD 1080P resolution
This monitor features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while working, gaming, or enjoying the latest in multimedia entertainment. -
Optimized view settings
ViewSonic's unique ViewMode feature offers "Game, " "Movie, " "Web, " "Text, " and "Mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications. -
Enhanced viewing comfort
Flicker-Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. -
Dual integrated speakers
Designed with dual integrated speakers, this monitor combines incredible screen performance with stereo sound for an immersive multimedia experience. -
EPEAT certified
With EPEAT certification, this monitor delivers a reduced environmental impact over the complete product lifecycle, making it a great eco-friendly, long-term investment. -
ENERGY STAR certification
This is an ENERGY STAR certified product that can save on energy costs while reducing greenhouse gases.
- ViewSonic Ergonomic VG2753 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 35 kWh
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Input Connectors
- HDMI, VGA, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 62.23 cm x 23.37 cm x 54.36 cm
- 6.4 kg
- Localisation
- Europe
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, GS, ICES-003, CB, DOC, RoHS, WEEE, cULus, ERP, RoHS2, EAC, CE/EMC, REACH SvHC
- (Austria, Germany, Switzerland - 3 years)
- Display Type
- Energy Class
- Class A
- 35 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 48 - 76 Hz
- Horizontal Refresh Rate
- 31 - 86 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Sync on Green, SuperClear, frameless bezel design, Composite Sync, ViewMode
- 62.23 cm x 23.37 cm x 54.36 cm - with stand
- 6.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , HDMI , DisplayPort , Microphone , Headphones , 2 x USB 3.0 downstream , USB 3.0 upstream , Mini DisplayPort
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Integrated cable management
- Cables Included
- 1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort , 1 x USB cable
- Localisation
- Europe
- Input Voltage
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- Without stand - width: 62.23 cm - depth: 5.33 cm - height: 37.08 cm - weight: 4.31 kg , With stand - width: 62.23 cm - depth: 23.37 cm - height: 54.36 cm - weight: 6.4 kg
Sustainability Information
- ENERGY STAR Certified
- Regional Warranty Exceptions
- Austria, Germany, Switzerland - 3 years
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
