The ViewSonic VA2465S-3 is a 24" widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920 x 1080 resolution, 3000:1 static contrast ratio and SuperClear VA technology, the VA2465S-3 delivers stunning color and contrast with amazing screen performance at any viewing angle. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, flicker-free technology and a blue light filter help to eliminate eye strain from extended viewing periods. Paired with VGA and DVI inputs, the VA2465S-3 allows flexible connection to PC systems, laptops and other multimedia devices. A VESA-mountable design offers additional mount flexibility. In addition, ViewSonic offers one of the industry's best pixel performance policies to provide a great value for the stylish, high-performance VA2465S-3 monitor.
Full HD 1080p for superior pixel performance
This monitor features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while working, gaming, or enjoying the latest in multimedia entertainment. -
SuperClear VA image enhancement technology with 95% sRGB coverage and wide viewing angles
SuperClear Image Enhancement Technology delivers the best color performance and extends display viewing angles to 178 degrees both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side - with no color distortion or decay. -
ViewMode settings for digital content
With five intuitive scenario presets, ViewSonic's unique ViewMode feature offers best-in-class screen calibration for accurate color rendering and excellent performance. -
ViewSonic flicker-free viewing for improved eye comfort
ViewSonic flicker-free displays eliminates screen flickering at all brightness levels to provide a more comfortable viewing experience. -
Blue light filter for more comfortable viewing
ViewSonic displays feature a blue light filter setting that allows users to adjust the amount of blue light emitted from the screen to increase eye comfort for work and multimedia applications. -
Better color depth with 3000:1 static contrast ratio
An ultra-high static contrast ratio of 3000:1 offers a wider range of grayscale to show deeper, richer colors with more visible details in shadows and highlights. With a ratio 3-times higher than standard panels, this monitor can display vivid and realistic images for photo editing, watching movies, or any multimedia application. -
Mercury-free LED backlighting
LED backlighting not only enhances monitor performance but it's also eco-friendly, mercury-free, and uses less energy than conventional monitors. -
Eco-mode conserves more energy and cuts costs
ViewSonic's proprietary Eco-mode energy-saving feature is built into all ViewSonic LED monitors. Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the monitor's lamp life.
- ViewSonic VA2465S-3 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 56.389 cm x 19.314 cm x 40.719 cm
- 4.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- CB, FCC, RoHS, WEEE, REACH, UkrSEPRO, ERP
- (Austria, Germany, Switzerland - 2 years)
- Display Type
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- SuperClear, Eco-Mode, Flicker Free technology, Mercury free, Blue Light Filter technology
- 56.389 cm x 19.314 cm x 40.719 cm - with stand
- 4.1 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Dimensions & Weight Details
- Without stand - width: 56.389 cm - depth: 4.596 cm - height: 34.709 cm - weight: 3.6 kg , With stand - width: 56.389 cm - depth: 19.314 cm - height: 40.719 cm - weight: 4.1 kg
Sustainability Information
- ENERGY STAR Certified
- Regional Warranty Exceptions
- Austria, Germany, Switzerland - 2 years
StarTech.com Articulating Monitor Arm | In Stock | £124.94 |
StarTech.com Dual Monitor Stand | In Stock | £82.12 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £84.28 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £95.48 |
