ViewSonic VA2265S-3 22" 1920x1080 5ms VGA DVI-D LED Monitor
Quicklinx: BH0FWS00 Mfr#: VA2265S-3
The ViewSonic VA2265S-3 is a 22" widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920x1080 resolution, 3000:1 static contrast ratio and SuperClear VA technology, the VA2265S-3 delivers stunning color and contrast with amazing screen performance at any viewing angle. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, Flicker-Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing period. Paired with VGA and DVI inputs, the VA2265S-3 allows flexible connection to PC systems, laptops and other multimedia devices. A VESA-mountable design offers additional mount flexibility. In addition, ViewSonic offers one of the industry's best pixel performance policies to provide a great value for the stylish, high-performance VA2265S-3 monitor.
  • Full HD 1080p for superior pixel performance
    This monitor features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while working, gaming, or enjoying the latest in multimedia entertainment.
  • Superclear VA image enhancement technology with wide viewing angles
    SuperClear Image Enhancement Technology delivers the best color performance and extends display viewing angles to 178 degrees both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side - with no color distortion or decay.
  • ViewMode settings for digital content
    With five intuitive scenario presets, ViewSonic's unique ViewMode feature offers best-in-class screen calibration for accurate color rendering and excellent performance. "Game, " "Movie, " "Web, " "Text, " and "Mono" presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications.
  • ViewSonic flicker-free viewing for improved eye comfort
    ViewSonic flicker-free displays eliminates screen flickering at all brightness levels to provide a more comfortable viewing experience.
  • Blue Light Filter for more comfortable viewing
    ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen to increase eye comfort for work and multimedia applications.
  • Better color depth with 3000:1 static contrast ratio
    An ultra-high static contrast ratio of 3000:1 offers a wider range of grayscale to show deeper, richer colors with more visible details in shadows and highlights. With a ratio 3-times higher than standard panels, this monitor can display vivid and realistic images for photo editing, watching movies, or any multimedia application.
  • Mercury-free LED backlighting
    LED backlighting not only enhances monitor performance but it's also eco-friendly, mercury-free, and uses less energy than conventional monitors.
  • Eco-mode conserves more energy and cuts costs
    ViewSonic's proprietary Eco-mode energy-saving feature is built into all ViewSonic LED monitors. Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the monitor's lamp life.
ViewSonic VA2265S-3 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
71% NTSC, 74% Adobe RGB, 96% sRGB
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 100/240 V (50/60 Hz)
51.069 cm x 19.314 cm x 38.761 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
CB, FCC, RoHS, WEEE, REACH, UkrSEPRO, ERP
(Austria, Germany, Switzerland - 2 years)
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
SuperClear, Eco-Mode, Flicker Free technology, Blue Light Filter technology
51.069 cm x 19.314 cm x 38.761 cm - with stand
3.6 kg
VGA , DVI
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Input Voltage
Power Consumption (Typical)
22 Watt
Dimensions & Weight Details
Without stand - width: 51.069 cm - depth: 4.716 cm - height: 31.938 cm - weight: 3 kg , With stand - width: 51.069 cm - depth: 19.314 cm - height: 38.761 cm - weight: 3.6 kg
Sustainability Information
ENERGY STAR Certified
Regional Warranty Exceptions
BH0F StarTech.com Articulating Monitor Arm In Stock £132.69
BH0F StarTech.com Dual Monitor Stand In Stock £91.00
BH0F StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
BH0F StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
