ViewSonic VA2261-2-E3 22" 1920 x 1080 5ms VGA DVI Monitor
Quicklinx: CQB8WS00 Mfr#: VA2261-2-E3
The ViewSonic VA2261-2 is an eye-care and environmentally friendly 22" widescreen monitor that features flicker-free and Blue Light technology, eliminating eye strain over extended viewing periods. Equipped with a LED backlight and Eco mode, it provides energy savings. With Full HD resolution, 5 ms response time, DVI and VGA inputs and a glossy finish design, the VA2261-2 is ideal for both home entertainment and office work. It also has ViewMode technology, including preset text, movie, game, mono, and web modes, allowing users to view better color rendering based on different using scenarios.
  • Full HD for superior pixel performance
    The ViewSonic VA2261-2 features Full HD resolution for incredible pixel-by-pixel image performance. You'll experience amazing clarity and detail whether it be while gaming or enjoying multimedia entertainment. A 16:9 widescreen ratio minimizes eye fatigue even after hours of playtime, and is perfectly compatible with multi-window viewing without toggling.
  • Planet-friendly mercury-free LED backlighting
    LED backlighting enhances display performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves energy. In addition, LED backlighting provides for a slim, lightweight profile that saves desktop space.
  • Eco mode conserves more energy
    ViewSonic's proprietary Eco mode feature is built into this monitor. It also features settings that save power. Especially in low ambient light, Eco mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the display's lamp life. With Eco mode, both lamp replacement and energy expenditures are reduced.
  • ViewSonic flicker-free viewing for improved eye comfort
    ViewSonic flicker-free displays deliver on the promise of more comfortable viewing. Rather than using Pulse Width Modulation that continuously turns the LED backlight on and off, ViewSonic flicker-free displays use DC modulation backlights that maintain a steady stream of direct current power - nearly eliminating screen flickering at all brightness levels by providing a constant LED light source. This lets you work at your computer, play games, or watch movies longer - without eye fatigue.
  • Blue Light Filter for more comfortable viewing
    Prolonged exposure to certain levels of blue light can cause eye discomfort. ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling longer viewing times and increased eye comfort for work and multimedia applications.
  • ViewMode settings for digital content
    Enjoy excellent performance and accurate color rendering for everything you view on this display. With different scenario presets, ViewSonic displays offer great calibration techniques to bring you amazing digital viewing experience.
ViewSonic VA2261-2 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
50.4 cm x 17.96 cm x 38.08 cm
2.64 kg
Europe
Environmental Standards
ENERGY STAR Qualified
CCC, RoHS, WEEE, REACH, CEL level 1
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Backlight Technology
WLED
Eco-Mode, 72% NTSC colour gamut
50.4 cm x 17.96 cm x 38.08 cm - with stand
2.64 kg
VGA , DVI-D
Mechanical
Tilt
VESA Mounting Interface
75 x 75 mm
1 x VGA cable
Backlight Life
30,000 hours
Europe
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
21.5 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 50.4 cm - depth: 4.75 cm - height: 31.05 cm - weight: 2.18 kg , With stand - width: 50.4 cm - depth: 17.96 cm - height: 38.08 cm - weight: 2.64 kg
Sustainability Information
ENERGY STAR Certified
10 - 90% (non-condensing)
CQB8 StarTech.com Articulating Monitor Arm In Stock £121.96
CQB8 StarTech.com Dual Monitor Stand In Stock £82.12
CQB8 StarTech.com TV/Monitor Arm - Wallmount In Stock £85.61
CQB8 StarTech.com Monitor Arm - Heavy Duty In Stock £95.48
