ViewSonic VA2246 22" 1920x1080 5ms DVI-D VGA LED Black Monitor
FULL HD RESOLUTION FOR SUPERIOR PIXEL PERFORMANCE
Quicklinx: 8TP4WS00 Mfr#: VA2246-LED
The ViewSonic VA2246-LED is a 22" (21.5 viewable) widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920 x 1080 resolution and a 10M:1 dynamic contrast ratio, the VA2246-LED delivers stunning brightness and contrast, while a quick 5 ms response time ensures crisp pictures and smooth playback. The display includes a VGA and DVI inputs provide flexible and convenient connectivity, while a VESA-mountable design offers additional mount flexibility. With an efficient LED backlight and energy-saving Eco mode, the VA2246-LED is an environmentally friendly display choice. In addition, along with one of the industry's best pixel performance policies provides great value for the stylish, high-performance VA2246-LED display.
  • Full HD resolution for superior pixel performance
    You can experience stunning clarity and detail with high-definition office, graphic design, video production, gaming and multimedia applications on ViewSonic's VA2246-LED monitor. It features Full HD 1920 x 1080p resolution to ensure excellent pixel-by-pixel image performance, while its 10,000,000:1 mega dynamic contrast ratio guarantees accurate image reproduction with rich, vibrant visual effects.
  • Mega dynamic contrast ratio for sharp, crisp images
    A superior dynamic contrast ratio of 10,000,000:1 better defines the relationship between the darkest and brightest colors, ensuring all displayed images are rich and detailed. Combined with an extremely fast 5 ms response time, every motion is naturally and accurately reproduced without any blurs.
  • ENERGY STAR certification
    The VA2246-LED is environmentally sound, complete with an energy-saving mercury-free LED backlight and Eco-mode. Its ENERGY STAR certification means you save up to 40% in energy costs when compared to regular 22" monitors.
  • Energy-saving eco-mode
    ViewSonic's proprietary Eco-mode function gives you the choice to optimize (75%) or conserve (50%) energy, thus reducing display brightness and conserving energy by up to 50%. Especially in low ambient light, Eco-mode adjusts brightness and improves visibility while reducing eye fatigue and prolonging the display's lamp life.
  • Windows 8 Certified compliance
    Windows 8 Certified, the VA2246-LED provides the most updated Windows 8 experience without any compatibility issues. You can experience the Windows 8 operating system with ViewSonic's VA2246-LED display.
ViewSonic VA2246-LED - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
50.96 cm x 19.76 cm x 36.61 cm
3.48 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
C-Tick, BSMI, CB, CCC, PSB, RoHS, WEEE, REACH, UkrSEPRO, ERP, CEL
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select
sRGB colour management, Eco-Mode, Mega Dynamic Contrast Ratio
50.96 cm x 19.76 cm x 36.61 cm - with stand
3.48 kg
DVI-D , VGA
Mechanical
Tilt
Tilt Angle
-5/+18
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Backlight Life
40,000 hours
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
22 Watt
Dimensions & Weight Details
With stand - width: 50.96 cm - depth: 19.76 cm - height: 36.61 cm - weight: 3.48 kg , Without stand - width: 50.96 cm - depth: 4.83 cm - height: 31.66 cm - weight: 3.13 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
10 - 90% (non-condensing)
