The ViewSonic VA2245a-LED is a 22" widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD resolution and dynamic contrast ratio, the VA2245a-LED delivers stunning brightness and contrast, while a quick response time ensures crisp pictures and smooth playback. A VESA-mountable design offers additional mount flexibility. With an efficient LED backlight and energy-saving Eco mode, the VA2245a-LED is an environmentally friendly display choice.
Full HD resolution for superior pixel performance
Experience stunning clarity and detail with high-definition office, graphic design, video production, gaming and multimedia applications on ViewSonic's VA2245a-LED monitor. It features Full HD resolution to ensure excellent pixel-by-pixel image performance, while its Mega Dynamic Contrast Ratio guarantees accurate image reproduction with rich, vibrant visual effects. -
Mega dynamic contrast ratio for sharp, crisp images
A superior dynamic contrast ratio of 10,000,000:1 better defines the relationship between the darkest and brightest colors, ensuring all displayed images are rich and detailed. Combined with an extremely fast 5ms response time, every motion is naturally and accurately reproduced without any blurs. -
Icon-energystar certification
The VA2245a-LED is environmentally sound, complete with an energy-saving mercury-free LED backlight and Eco-mode. -
VESA mount and Kensington security lock compliant
Designed for use in various settings, the VA2245a-LED's robust design makes it safe and secure wherever it is installed. That's because it comes with a Kensington security lock slot and is VESA wall mount compliant - making it the perfect monitor for all office and public settings.
- ViewSonic VA2245A-LED - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 700:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- VGA
- Tilt
- 50.96 cm x 19.76 cm x 36.61 cm
- 3.48 kg
- Environmental Standards
- ENERGY STAR Qualified
- CB, RoHS, WEEE, REACH, UkrSEPRO, ERP
- 2-year warranty
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- Eco-Mode, Mega Dynamic Contrast Ratio
- 50.96 cm x 19.76 cm x 36.61 cm - with stand
- 3.48 kg
- VGA (HD-15)
Mechanical
- Tilt
- Tilt Angle
- -5/+18
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- Power Supply
- Internal
- Power Consumption (Typical)
- 22 Watt
- Dimensions & Weight Details
- With stand - width: 50.96 cm - depth: 19.76 cm - height: 36.61 cm - weight: 3.48 kg , Without stand - width: 50.96 cm - depth: 4.83 cm - height: 31.66 cm - weight: 3.13 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
