ViewSonic's price-performance VA2214S 22" (21.5" viewable) Full HD display with 1920 x 1080 native resolution delivers great color performance and energy efficiency. With SuperClear VA technology and an advanced VA LED panel, the VA2214S offers extremely wide 178°/178° viewing angles for consistent color performance, and 3,000:1 native contrast ratio for sharp, crisp image quality. Windows 8 compatibility, VESA wall mount compliance and Energy Star certification are standard features, as well as an energy-saving Eco-mode. Plus, its glossy-finish design with integrated DVI and VGA inputs make the VA2214S a stylish and flexible display solution for office work or home entertainment.
SuperClear VA LED for extremely wide viewing angles
SuperClear VA technology eliminates image distortion and color shifting, even at extreme angles. You will experience true color, even from a 178-degree viewing angle, with the VA2214S VA panel. -
ENERGY STAR qualified energy-efficient product
The VA2214S is environmentally sound, complete with an energy-saving LED backlight and eco-mode. It's ENERGY STAR certification means you save up to 40% in energy costs when compared to regular 22" monitors. -
1080p Full HD for high-definition application
Full HD 1080p resolution delivers stunning image quality with superior detail and sharpness for home and business applications. Ideal for graphic design, video production, and advanced business applications requiring professional monitor performance. -
Energy-saving eco-mode reduces energy costs
ViewSonic's proprietary 'eco' mode function provides "optimize" (75%) and "conserve" (50%) backlighting output options. This reduces the backlighting output, based on different working scenarios and saves up to 50% on power consumption. Consequently, this prolongs the display lifespan and lowers the total cost of ownership. Eco mode provides a more comfortable working environment, especially for those who work for extended periods of time.
- ViewSonic VA2214S - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 10000000:1 (dynamic)
- Response Time
- 6 ms
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.11 cm x 18.99 cm x 39.18 cm
- 2.82 kg
- Environmental Standards
- ENERGY STAR Qualified
- NEMKO, CB, RoHS, WEEE, REACH, UkrSEPRO, ERP
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 6 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- SuperClear, Eco-Mode
- Black
- 51.11 cm x 18.99 cm x 39.18 cm - with stand
- 2.82 kg
- DVI-D , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 23 Watt
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- Without stand - width: 51.11 cm - depth: 5.27 cm - height: 30.94 cm - weight: 2.61 kg , With stand - width: 51.11 cm - depth: 18.99 cm - height: 39.18 cm - weight: 2.82 kg
Sustainability Information
- ENERGY STAR Certified
