The ViewSonic VA2046a-LED is a 20" widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With 1600x900 resolution and a 10M:1 dynamic contrast ratio, the VA2046a-LED delivers stunning brightness and contrast, while a quick 5ms response time ensures crisp pictures and smooth playback. VGA inputs provide flexible and convenient connectivity, while a VESA-mountable design offers additional mount flexibility. With an efficient LED backlight and energy-saving Eco mode, the VA2046a-LED is an environmentally friendly display choice. In addition, a 2-year warranty, along with one of the industry's best pixel performance policies provides great value for the stylish, high-performance VA2046a-LED display.
High Resolution for Superior Pixel Performance
Experience stunning clarity and detail with high-definition office, graphic design, video production, gaming and multimedia applications on ViewSonic's VA2046a-LED monitor. It features 1600x900 resolution to ensure excellent pixel-by-pixel image performance, while its 10,000,000:1 Mega Dynamic Contrast Ratio guarantees accurate image reproduction with rich, vibrant visual effects.
Mega Dynamic Contrast Ratio for Sharp, Crisp Images
A superior dynamic contrast ratio of 10,000,000:1 better defines the relationship between the darkest and brightest colors, ensuring all displayed images are rich and detailed. Combined with an extremely fast 5ms response time, every motion is naturally and accurately reproduced without any blurs.
Energy-Saving Eco-Mode
ViewSonic's proprietary Eco-mode function gives you the choice to optimize (75%) or conserve (50%) energy, thus reducing display brightness and conserving energy by up to 50%. Especially in low ambient light, Eco-mode adjusts brightness and improves visibility while reducing eye fatigue and prolonging the display's lamp life.
Windows® 8 certified compliance
Windows® 8 Certified, the VA2046a-LED provides the most updated Windows® 8 experience without any compatibility issues. Experience the all-new Windows 8 operating system with ViewSonic's VA2046a-LED display
VESA Mount and Kensington Security Lock Compliant
Designed for use in various settings, the VA2046a-LED's robust design makes it safe and secure wherever it is installed. That's because it comes with a Kensington security lock slot and is VESA wall mount compliant - making it the perfect monitor for all office and public settings.
High resolution for superior pixel performance
Experience stunning clarity and detail with high-definition office, graphic design, video production, gaming and multimedia applications on ViewSonic's VA2046a-LED monitor. It features 1600 x 900 resolution to ensure excellent pixel-by-pixel image performance, while its 10,000,000:1 mega dynamic contrast ratio guarantees accurate image reproduction with rich, vibrant visual effects. -
Mega dynamic contrast ratio for sharp, crisp images
A superior dynamic contrast ratio of 10,000,000:1 better defines the relationship between the darkest and brightest colors, ensuring all displayed images are rich and detailed. Combined with an extremely fast 5 ms response time, every motion is naturally and accurately reproduced without any blurs. -
Energy-saving eco-mode
ViewSonic's proprietary eco-mode function gives you the choice to optimize (75%) or conserve (50%) energy, thus reducing display brightness and conserving energy by up to 50%. Especially in low ambient light, eco-mode adjusts brightness and improves visibility while reducing eye fatigue and prolonging the display's lamp life.
- ViewSonic VA2046A-LED - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 47.82 cm x 19.76 cm x 36.02 cm
- 3 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- FCC Class B certified, UL, C-Tick, BSMI, cUL, NOM, SASO, TUV S, CB, CCC, PSB, RoHS, WEEE, GOST-R, UkrSEPRO, CEL
- Display Type
- Diagonal Size
- 20"
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Brightness
- 200 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Backlight Technology
- WLED
- Eco-Mode, Mega Dynamic Contrast Ratio
- Black
- 47.82 cm x 19.76 cm x 36.02 cm - with stand
- 3 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+18
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Backlight Life
- 40,000 hours
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 18 Watt
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- Without stand - width: 47.82 cm - depth: 4.9 cm - height: 30.18 cm - weight: 2.6 kg , With stand - width: 47.82 cm - depth: 19.76 cm - height: 36.02 cm - weight: 3 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
