The ViewSonic SD-Z225 22" (21.5" viewable) zero client monitor is based on Teradici Tera 2321, with hardware accelerated PCoIP support. The SD-Z225 zero client is the perfect solution for companies seeking a seamless desktop experience, with ultra-high security and reliability in networks based on VMware technology. The SD-Z225 is a true zero client and features no local memory or moving parts for the ultimate in energy savings and reliability. The VMware-certified design guarantees performance and compatibility in your network. With the additional DVI output, flexible support is provided for dual-monitor productivity. The eco-friendly design with LED display uses up to 80% less energy consumption than standard PCs.
True personal PC experience
The SD-Z225 supports 2D/3D graphic intensive applications and a rich multimedia experience at full frame rates over Gigabit Ethernet. This is the no-compromise solution for demanding users. -
Easy deployment and management
Deploy users up to 5 times faster than traditional PC-based clients, and enjoy ongoing simplified management without need for constant patches and system updates. -
Dual-display productivity
With DVI-I video output, you can easily attach an additional VGA or DVI monitor for dual-display productivity. -
Simplified and secure management
The Teradici PCoIP management console provides for centralized deployment and management. With web-based access, administrators will be able to configure, update, manage, and even remotely control the power state for all of their PCoIP-based zero clients throughout the network. -
Low Total Cost of Ownership
All of the benefits of a virtual desktop deployment can be realized with ViewSonic's SD-Z225 zero client monitor. From simple and quick deployment, enhanced security with no local HDD, increased reliability and higher productivity - the SD-Z225 is an efficient and low-cost choice for virtualizing desktops.
- ViewSonic SD-Z225 - all-in-one Tera2321 - 512 MB - no HDD - LED 22"
- Thin client - all-in-one - tilt adjustment, white LED lamp, PC over IP (PCoIP) technology, VMware Ready
- Localisation
- Region: Europe
- Processor
- 1 x Teradici Tera2321
- RAM
- 512 MB DDR3 SDRAM
- Flash Memory
- 0 GB
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Monitor
- 22" - LED - 1920 x 1080 (Full HD)
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- No operating system
- Software Included
- ViewSonic Wizard, VMware PCoIP
- 51.64 cm x 18.99 cm x 39.27 cm
- 5.1 kg
- Thin client
- Product Form Factor
- All-in-one
- Built-in Devices
- Display
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Teradici Tera2321
- CPU Qty
- 1
RAM
- Installed Size
- 512 MB
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1066 MHz
Flash Memory
- Flash Memory
- 0 GB
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- LED
- Diagonal Size
- 22"
- Native Resolution
- Widescreen Display
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Response Time
- 5 ms
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare, Zero Client, Hard Coating (3H)
Graphics Controller
- Video Interfaces
- VGA, DVI
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Speakers Included
- 2 x right / left channel
- Data Link Protocol
- 1 x LAN (Gigabit Ethernet) , 1 x DVI-I output , 4 x USB 2.0 , 1 x VGA input , 1 x audio line-in - mini-jack , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Cables Included
- VGA cable
- Tilt adjustment, white LED lamp, PC over IP (PCoIP) technology, VMware Ready
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm
- Power adapter
- Voltage Required
- 28 Watt
Operating System / Software
- OS Provided
- Software
- 51.64 cm
- 18.99 cm
- 39.27 cm
- 5.1 kg
- 0 °C
- 35 °C
- 15 - 90% (non-condensing)
