The ViewSonic SC-T45 thin client PC uses the powerful Intel Atom processor. The SC-T45 is optimized for all of the major remote networking protocols including Citrix ICA/HDX, VMware PCoIP, and Microsoft RemoteFX - making it a versatile virtualization solution with endless possibilities. The SC-T45 has the horsepower needed to handle a large portion of local processing and graphics rendering, and the flexibility to operate as a stateless device in a VDI-based infrastructure. The SC-T45 is also an energy and space saver, consuming only 14 W of power and easily attaching to your VESA-ready monitor with the included VESA bracket. The SC-T45 thin client is the perfect solution for companies seeking the benefits of true PC-like performance, along with simplified management and lower total cost of ownership. ViewSonic's thin clients are the smart choice for optimizing your virtual desktop deployment.
Powerful computing combination
With an Intel Atom processor, the SC-T45 is equipped to handle the highest demands of both virtual and local processing, including the most 2D/3D graphic intensive applications. -
Easy deployment and management
Deploy users up to 5 times faster than traditional PC-based clients, and enjoy ongoing simplified management without the need for constant patches and system updates. -
Flexible design
Future-proof your network with this flexible thin client and rest assured that you will be supported even if your virtualization needs change later. The SC-T45 is ViewSonic's most flexible offering for supporting MS, Citrix, or VMware view. -
Low total cost of ownership
With easier and faster deployment, simplified management, and increased reliability and security, the benefits and efficiency of ViewSonic's SC-T45 lead to a lower cost of ownership.
- ViewSonic SC-T45 - USFF - Atom N2800 1.86 GHz - 2 GB - flash 4 GB
- Thin client - ultra small form factor - PC over IP (PCoIP) technology, Citrix Ready, VMware Ready
- Localisation
- Region: Europe
- Processor
- 1 x Intel Atom N2800 / 1.86 GHz (Dual-Core)
- Cache Memory
- 1 MB
- Cache Per Processor
- 1 MB
- RAM
- 2 GB DDR3 SDRAM
- Hard Drive
- Flash 4 GB
- Optical Storage
- No optical drive
- Networking
- GigE
- OS Provided
- Microsoft Windows Embedded Standard 7
- Software Included
- ViewSonic Wizard, ViewSonic Device Manager, ViewSonic Client Setup
- 3.95 cm x 10.3 cm x 14.3 cm
- 500 g
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Recommended Use
- Small business, corporate business, education, government
- Product Form Factor
- Ultra small form factor
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Atom N2800
- Clock Speed
- 1.86 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Chipset Type
- Intel NM10 Express
Cache Memory
- Installed Size
- 1 MB
- 1 MB
RAM
- Installed Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1066 MHz
Hard Drive
- Flash
- Capacity
- 4 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA, DVI
- Max Monitors Supported
- 2
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support
- 4 x USB 2.0 (2 front, 2 rear) , 1 x DVI-D , 1 x VGA , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-in - mini-jack (1 in front) , 1 x headphones - mini-jack (1 in front)
- Included Accessories
- VESA mounting kit
- VESA Mounting Interface
- 100 x 100 mm
- FCC, RoHS, WEEE, REACH, NRTL
- Power adapter
- Power Provided
- 36 Watt
- 14 Watt
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- 3.95 cm
- 10.3 cm
- 14.3 cm
- 500 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
