The ViewSonic LightStream PJD7835HD Full HD projector features high brightness and excellent contrast, native 1080p resolution and optimal throw ratio for larger screens from shorter distances. Flexible connectivity is provided by HDMI ports, which also offer support for Wi-Fi dongles. Outstanding color & sound performance is powered by a special SuperColor feature and SonicExpert audio technology, whilst a hidden HDMI-MHL compartment and a rear cable cover complete the sleek design.
Full HD delivers extremely fine picture quality
This ViewSonic projector features Full HD 1080p native resolution for extra sharp and clear picture. It is perfect for watching most types of personal high-definition content including movies, videos, sports, games, and TV. HD is also now demanded in numerous business applications like finance, medical and design. -
HDMI ports with 3D support
Equipped with HDMI ports, this projector is perfect for connecting to any HDMI-enabled device such as laptops, tablets, games consoles and DVD or Blu-ray players. It also supports 3D images directly from 3D sources. -
Larger screens from shorter distances
A shorter than normal throw ratio projects large images from reduced distances in small rooms. The lens with optical zoom also provides positioning flexibility by creating significantly larger screens without having to move the projector. -
Perfectly shaped ages
Horizontal and vertical keystone correction and 4 corner adjustment features eliminate crooked and distorted images for a perfectly proportioned picture every time. -
Beautiful design with rear cable cover
With its dot texture finish, curved edges and tactile keypad this LightStream projector stands out from the competition. A concealed HDMI-MHL port and rear cable cover provides security and completes the look by hiding cable clutter and exposed ports. -
SuperColor technology for superb color accuracy
ViewSonic's SuperColor technology offers a wider color range than conventional DLP projectors for true-to-life color performance in any light, while the SuperColor technology maximizes brightness. -
SonicExpert technology for beautiful sound
ViewSonic's SonicExpert technology incorporates a ported speaker chamber and a more powerful amplifier to deliver much higher volume and outstanding sound. -
Quiet operation
A built-in thermal sensor control system and a large fan effectively keep the projector cool while intelligently minimizing fan speed, reducing noise and saving on energy consumption. -
Easy-to-use preset color modes
With 5 preset color modes, users can choose the best one to suit their material: Brightest, Dynamic, Standard, ViewMatch or Movie.
- ViewSonic LightStream PJD7835HD - DLP projector - 3D - black
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Black
- Built-in Devices
- Speaker
- Localisation
- United States
- Brightness
- 3500 lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 250 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM D/K, SECAM B/G, M-NTSC, SECAM L1)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 315 Watt
- 36.2 cm x 23.1 cm x 10.9 cm
- 2.8 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Speaker
- Enclosure Colour
- Black
- Localisation
- United States
Projector
- Brightness
- 3500 lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.7 m - 9.7 m
- Throw Ratio
- 1.1 - 1.5:1
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1080 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 250 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Super Color, DynamicEco Mode, SonicExpert
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.36x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM D/K, SECAM B/G, M-NTSC, SECAM L1
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- UL, TUV GS, C-Tick, SASO, TUV S, CB, EMC, DOC, PSB, FCC, RoHS, KCC, WEEE, REACH, UkrSEPRO, KC, ERP, CECP, EAC, SVHC, CoC
- Power Source
- AC
- Voltage Required
- 315 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 36.2 cm
- 23.1 cm
- 10.9 cm
- 2.8 kg
- Limited warranty - 3 years , Limited warranty - lamp - 1 year , Limited warranty - express exchange - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 28 dB
