For an incredible audiovisual experience at a great value, the ViewSonic LightStream PJD7828HDL projector delivers. Perfect for home entertainment, this projector features 3200 lumens, Full HD resolution, an intuitive, user-friendly design, and a sleek chassis. The SuperColor technology offers a wide color range for true-to-life image projection in any light, while SonicExpert, powers a 10 W speaker to deliver incredibly clear and audible sound. With a shorter throw ratio, 1.3x optical zoom, smart design, and extensive connectivity, the PJD7828HDL provides flexible and quick setting up in any home.
Great color accuracy
ViewSonic's proprietary SuperColor technology offers a wider color range. With a 6-segment color wheel design and dynamic lamp control capabilities, SuperColor technology projects images with reliable and true-to-life color performance, in both bright and dark environments, without sacrificing image quality. -
Stunning resolution and brightness
This projector features Full HD resolution for sharp and clear picture. It is perfect for watching high-definition content, including movies, videos, sports, games and TV, without any distortion or scaling of the original video format. -
SonicExpert technology
This LightStream projector is designed with SonicExpert technology that incorporates an enlarged speaker chamber and a more powerful amplifier. An integrated speaker captivates your audience with immersive sound. -
PortAll: discreet wireless streaming
This projector includes ViewSonic's PortAll feature - a hidden compartment with an integrated and secure MHL/HDMI port that lets you discreetly stream multimedia content from a wireless dongle, or lets you connect to other devices via an HDMI cable. What's more, an integrated Micro-USB cable lets you quickly and easily power other Micro-USB devices.
- ViewSonic LightStream PJD7828HDL - DLP projector - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Keypad
- Bundled Services
- 1 year Express Exchange Service
- Localisation
- Americas
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours (30-bit)
- Bulb type
- 210 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- S-Video, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 300 Watt
- 31.6 cm x 22.8 cm x 10.37 cm
- 2.4 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Keypad
- Bundled Services
- Localisation
- Americas
Projector
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 1.29 m - 14.28 m
- Throw Ratio
- 1.15 - 1.5:1
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1080 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 210 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction, zoom, focus
- MHL compliance, SonicExpert, PortAll, ViewSonic SuperColor, elevation feet
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - mini-USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Cable cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security Slot Type
- Kensington security slot
- C-Tick, NOM, SASO, TUV S, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, cTUVus, REACH, KC, ERP, CECP, EAC, SVHC
- Power Source
- AC
- Voltage Required
- 300 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 31.6 cm
- 22.8 cm
- 10.37 cm
- 2.4 kg
- Shipping Width
- 41 cm
- Shipping Depth
- 45 cm
- Shipping Height
- 22.5 cm
- Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 30 dB
